Home > For Sale & Wanted > [Sold] MY07 (56) Range Rover 4.2 Supercharged Reduced |
quavey Member Since: 22 Jan 2017 Location: Lancaster Posts: 292 |
As much as it pains me to sell this wonderful car. I've been to view a few M5's and the bit is between my teeth now. I am willing to take a sensible offer. I still think this is the cheapest MY07 Supercharged on the market that I can find but the worst I can say is no 2005 E60 M5
14th Feb 2018 10:33am |
Sold pending delivery 2005 E60 M5
27th Feb 2018 11:31am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
Off topic which m5 you going for e60 or f10? I currently run the v10 and the fuel bills are about 1/3 LESS than the ff dispite the bonus cylinders and extra cc. If it’s an e60 be very very careful about early 05-08 models as they have catastrophic rod bearing failures which are well documented. I know first hand as my m6 had this luckily under warranty. I got a brand new final spec (3rd edition) s85 which seems to reduce the issue substantially (I don’t want to say eliminate as that’s a curse for sure and I have no warranty now) so I would be looking Lci if I were you. The newer spec engines have two sump bungs the old only one. They are awesome cars had mine for the best part of 8years I can’t bring myself to sell it as when else will I ever own and afford a v10 again! If your looking at an f10 ignore all that Current stable:
5th Mar 2018 12:56pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
If your fuel bills in the m6 are less than the FF , your not driving it properly !!!!
5th Mar 2018 1:20pm |
haha - I assure you I am I think the problem is I drive the ff hard too Current stable:
5th Mar 2018 1:31pm |
2015 4.4 AB
5th Mar 2018 1:32pm |
Yes I was quite surprised on the way home yesterday the M5 managed 24.5mpg. Figures that can only be dreamed of in the old Supercharged considering I was cruising at a higher speed than I would in the FF as well.
6th Mar 2018 10:24am |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
I have an e61 M5 - wicked and rare cars.
6th Mar 2018 3:15pm |
Haha thanks.
6th Mar 2018 3:21pm |
Yes, 60 litres is a joke. You'll be doing well to get 200 miles to a tank Alex
6th Mar 2018 3:27pm |
You do definately roll the dice the newer bearing clearances are definitely better but not fool proof. What I like is how quiet the vamps is on the newer engine, I have seen an 06 on the board with over 150k and and 08 with over 200k - since the new engine I don’t rev over 3k until oil is up to temp before giving the beans... are you going to be doing many miles with it do you think? When did it last have a clutch and flywheel? I’m on my 3rd set 40k tops they last, tbh aside from that a fuel pump and alternator in the last 8yrs she’s not been bad... Current stable:
6th Mar 2018 8:14pm |
It had its first clutch and flywheel at 63k its now on 79k so should be plenty of life in it yet. I only do 5k a year or so. It's just had brakes tyres and throttle actuators in last 12 months 2k miles and had an SMG pump at 70k so its had most of the major work done. 2005 E60 M5
7th Mar 2018 9:53pm |
Nice - hopefully you enjoy her! You’ll have your coils die one by one next common around that mileage - if your feeling flush you can do all 10 (diy is not too bad) or if your feeling poor like I was when the first one went you can do one at a time over two years... but risk limp mode as your new friend! Not sure if I’m allowed to recommend other forums but m5 board is good for all things non ff Current stable:
7th Mar 2018 9:56pm |
