![]() | Home > Maintenance & Mods (L322) > Corrosion on tail pipe trim |
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
lets have a look at them then.... 2003 Range Rover Vogue 4.4 on Gas
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Don’t know if you will get away with it as it will probably be linked to ViN, but I think LR have a recall for the corrosion on the finishers. I’m pretty sure they are available as a separate item. There is nothing that can't be fixed with a hammer😜😜
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
heres a before and after - the plating on this isn't coming off... yet the other one has bits peeling... gutted about the recall ... oh well think I will put about ten million coat of vat silver paint on
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1418 ![]() ![]() ![]() |
Aluminium alloy on motorcycles could be cleaned with Solvol polish, that might work here too, perhaps preceded by some fine emery paper or steel wool. After that Q spray with clear lacquer? Only Range Rovers since 1988 |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
I’ve two sets and both peeled and flaked so left a pair with a friend to shot blast and then will ask the wheel refurb company by me to see if they can powder chrome like the wheels they do 🙏 _____________________________________________________
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 ![]() ![]() ![]() |
I would give powder coating a try as well. Have them media blasted with glass or aluminium oxide and then two runs of powder coating primer, first one to fill in the small craters, then sand down and flush slightly, followed by a second coat in whatever colour you like.
If you are prepared to pay for the job to be done professionally, I would anticipate Badger Anodising in Birmingham could refurbish these as new. £80 to get 4 aluminium tread plates refurbished to as new/ proper job condition. Have used them for years. Honest, excellent communication and completely professional. http://www.fullfatrr.com/forum/topic44108.html?highlight=badger ![]() |
Found a place to blast powder and paint for £50 left with them Current stable:
