![]() | Home > Maintenance & Mods (L322) > Rocker cover help |
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086
I doubt if it will do much, i suppose it could block an oil way but more likely get smashed by a cam lobe.
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2256
Lol I was going to say there was no slack on the chains - guessing that’s good news for the chains and I still have no startup rattle |
Also here is a video of the noise in park like a knock knock sound Current stable:
If the gasket isn't leaking then don't worry, you could just loosen the bolts and tuck it back in and then tighten again. You did have all the metal collars in place to stop the bolts from tightening down too much ?
Ok Great - so that noise is it definately engine not the rest of the drivetrain as it goes in drive? Wondered if it could be propsgaft coupling or something Current stable:
very hard to tell from the video, if you open your bonnet and listen to where the noise is coming from which is harder than it sounds, not sure if that is a pun.
I had the windows down and could distinctly hear the different - will try to get a video but if you reckon a lot have that sound maybe it’s just an age thing and I’m adding more worry to the list I shouldn’t need to as to be fair it drives ok [/u] Current stable:
I have found dozens of tapping sounds and everyone seems to solve it a different way or not at all.
I will say this - you have probably checked but check the torque of your plugs I had four out of 8 backed out it fixed one of my noises and seems common on the BMW forums Current stable:
ok thanks, I did start to do that yesterday but got as far as No 1 and realised that my multimeter that i was using to check the coils resistance couldn't even check it's own resistance. |
do you know what the resistance should be out of curiosity - on the mw forum no one could give me an accurate answer... I have a box of 8 coils I've accumulated over my bmw years and I don't know what are good/bad! Current stable:
Not sure if it’s because I got a better picture or if it’s got worse not sure why I’m
