![]() | Home > In Car Electronics (L322) > Reverse camera |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Seems an obvious thing to say but it looks like it needs pointing down a bit!!! 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
What sort of camera is it. I've read somewhere else on here that only an NTSC camera will work properly. Plus, if the camera is designed to be mounted in a lower position then the lines will never be right as it will be operating at the wrong angle. The lines are produced by the camera so you can cut the wire that produces them. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I'd say that your NTSC camera is PAL, I don't suppose you brought it direct from Ping Ponk, they have a nasty habit of listing one thing and supplying something that looks right, but might have the wrong guts for the job..
Something like this might sort the problem https://www.ebay.co.uk/itm/PAL-to-NTSC-NTS...SwgspZsSoZ
Simran0211 Member Since: 10 Jun 2016 Location: Coventry Posts: 300 ![]() ![]() ![]() |
I had the tailgate up at the time but I’m not far away from Birmingham international |
It was just a thought, cos it's pot luck with what you buy and what you actually recieve.. if that little box sorts it, it'll save a heap of reworking |
uzp315 Member Since: 19 Nov 2017 Posts: 428 ![]() |
I had a similar situation. For my third attempt to get this right - I bought this one and it has worked fine.
Hi Miggit |
That I think is the trouble the NTSC/PAL switching is automatic, or imaginary, and it don't do BMW / LR |
Knightmare Member Since: 22 Jun 2015 Location: Kent Posts: 84 ![]() ![]() ![]() |
I too have done this switch several times, but to no avail. I've ordered NTSC only (apparently) and got the same black and white distorted image. So I did it again and order a PAL camera only to end up with the same outcome. What's annoying is when you switch the signal via the diagnostic menu, it works fine...just doesn't stay set obviously.
Maybe worth giving them a quick call too ? Just to make it clear it needs to be NTSC? Phone number is on the ebay ad. Goodluck. |
I feel that way aswell please let me know if you have any luck cheers |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
The thing is the guys in UK are buying the exact same ones anyway see all the images that they are using from our favourite sellers in China or Hong Kong and selling them on for 5 times the price so little bit of common sense to be used here! Worth a punt at £4.90 with free delivery! Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
