Home > Technical (L322) > Isofix car seats
muppet
United Kingdom 2012 Range Rover Westminster 4.4 V8 Barolo Black
Isofix car seats
Have a 2012 Westy and having immense problems trying to connect an Isofix car seat into the rear seats, I have used Isofix for many years in many different cars but for some reason the bars that the car seat is supposed to click into appear to be too low as though the car seat has to be put in at an angle to connect, just wondered if anyone else had experienced problems fitting them in...My previous Disco had no issues but the L322 appears to prove more difficult....Thanks ! I need more help than most...sorry !!
Post #466390 28th Jan 2018 8:37pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
Yes dead right they are a pain.
Post #466391 28th Jan 2018 8:51pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
They are hard and a tight fit I found getting one side pressed in first at an angle then pushing other in works using the front seat with my back pressed as leverage, also on other seat I use a seat belt with an isofix strap off the bay to go across the the bottom off the seat into the hooks. _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #466401 28th Jan 2018 10:39pm
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
I fitted some latch guides to make life easier. See https://www.pramcentre.co.uk/car-seats-car...7EQAvD_BwE
Post #466422 29th Jan 2018 9:53am
muppet
Thank-you so much Martin, I didn’t realise these existed, just bought 2 to try but if it does what is says, it will be perfect…
I assume it doesn’t inhibit the safety side but just acts as a guide when fitting them in…
Great advice and greatly appreciated…. I need more help than most...sorry !!
Post #466426 29th Jan 2018 10:10am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
I kind of poke my finger in the space between the seat back and base to make sure I'm lined up, practice makes perfect, and slightly pushing the seat foam down helps too.
Post #466522 29th Jan 2018 9:50pm
