Home > Technical (L322) > Engine comparison
Danwilderspin
Engine comparison
Hi all - so apologies if this is been done but I couldn’t find it...
I am after a break down of the engine options over the years to try to work out what my next step may be when I want a change.
As far as I’m aware there are 7 options,
BMW 4.4 V8
BMW 3.0 TD6
AJ 4.4 V8
AJ 4.2 s/c
AJ 5.0 s/c
AJ 3.6 TDV8
AJ 4.4 TDV8
Now I only really know about the top two, I know the 4.4 suffers from leaky gaskets and pcv issues, plus blocked oil coolers and eas for the gearbox not to mention the lifelong gearbox problems, and the chain guides failing. Not to mention valley pan leaking - overly complicated alternator failures
The td6 I don’t hear too much negativity about aside from the occasional turbo and the lovely gearbox which I believe was lifted straight out of a BMW saloon and dropped in with no consideration of weight changes etc so it will inevitably die at 100k...
The 4.4 AJ and 4.2 I know nothing about major issues with these, some say the valve seats are softer if using lpg but that’s all I see, I also believe from reading the gearboxes are better than the 5hp24 if cared for...
The two tsv8’s I don’t know why but people seem to think reliability is with the 4.4 not sure why I know one cracks oil coolers from reading on here also turbo go etc but not sure how much of a problem these really do have...
Any thing on here would be really useful and potentially for new buyers!
Cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #466411 29th Jan 2018 12:36am
holidaychicken
Man you have got it bad !!
You are what may be referred to as Range Rover Censored ed Very Happy
https://www.amazon.co.uk/gp/aw/d/B005WTCHZ...VQ99Z7G63J
5.0 SC I think have timing chain issues around 100K I believe , may have been rectified in the later ones but I onky really know anything about the 02-05 BMW ones really
Post #466416 29th Jan 2018 12:58am
Danwilderspin
Awesome see stuff I didn’t know. How about the 4.2? I would think that would be what I ended up getting next Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #466419 29th Jan 2018 9:03am
holidaychicken
I have not heard any horror stories but any car could be bad if not looked after previously, can't really tell you much but i'm sure others on here will be able to
Post #466421 29th Jan 2018 9:38am
mjdronfield
The oil cooler issues on the 4.4 TDV8 doesn’t take the engine with it, whereas turbos stuffing up on the 3.6 TDV8 tends to end up with the engine lunching on them and needing replacement. Some say the 3.6 issues are less pronounced than on the RRS as there is more cooling space under the bonnet of the FF so less heat issues.
I spent more money and skipped the 3.6 due to possible turbo issues.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #466497 29th Jan 2018 7:13pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
You could map out the egr's on the 3.6 TDV8 and worry not. Dodgy EGR's start the turbo failure chain reaction. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #466545 30th Jan 2018 12:08am
mjdronfield
True....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #466627 30th Jan 2018 6:37pm
rar110
My 3.6 tdv8 has been great, now with over 270,000km. It’s been smooth, powerful, reliable, and relatively economical. However I’ve read good reports about the 4.2 SC and AJ 4.4 NA. Especially the later terrain response models.
I’ve not read a lot about problems with the 5.0 v8s. However, they sound a lot more complex than the earlier AJ v8s.
However, the pick seems to be the 4.4 tdv8, unless doing few km, then consider an AJ v8. ______________________________
Post #466653 30th Jan 2018 9:13pm
Sandyt
My 4.2 is on 153k miles and going strong runs smooth uses no oil and comp test shows all good Thumbs Up Thumbs Up -I have done 90k of those miles
Post #466673 30th Jan 2018 10:30pm
