Home > Technical (L322) > td6 oil leak , help
darrenmax
Belgium 2003 Range Rover Vogue Td6 Giverny Green
td6 oil leak , help
i seem to have an oil leak around the turbo area, but cant quite see it, i need to remove the complete air filter housing, i removed the top halve and rocker cover but cant seem to see how to remove the bottom halve, anybody know how its done or have any photos ? 2002 td6 vogue, 06 supercharged facelift
Post #46645 19th Jan 2011 6:32pm
darrenmax
help Whistle 2002 td6 vogue, 06 supercharged facelift
Post #46808 20th Jan 2011 8:04pm
sorry mate i dont know..but have you used the search...
Post #46809 20th Jan 2011 8:05pm
darrenmax
yeah but nothing comes up for the bottom halve 2002 td6 vogue, 06 supercharged facelift
Post #46810 20th Jan 2011 8:11pm
what about RAVE darren..
Post #46811 20th Jan 2011 8:17pm
darrenmax
i dont have it, we bought a new pc with windows 7 and cant get it to work Sad 2002 td6 vogue, 06 supercharged facelift
Post #46815 20th Jan 2011 8:35pm
Remove the top cover, the air filter then you will need to loosten the ties for the wiring loom and move the loom to one side, the remaining airbox should then be removed by unbolting.
Post #46920 21st Jan 2011 5:59pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
And then RAVE will work?
Sorry, couldn't resist that's a really simple guide- good info! Thumbs Up
Post #46938 21st Jan 2011 7:42pm
darrenmax
got rave working but theres nothing in there, ill check the ties and wiring loom tomorrow, thanks 2002 td6 vogue, 06 supercharged facelift
Post #46939 21st Jan 2011 7:45pm
There is a page somewhere on the internet about doing this job, but as I'm on my laptop and a slow connection just now I can't look it up.
Post #47008 22nd Jan 2011 5:16pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Your going to love this..
The air box will require reomoval of the injector harness and injectors to get the air box lower section off. I had this trouble when I replaced the turbo. The access from below is near on impossible to check the oil feed / return from the turbo.
Don't run it like that or you stand a good chance of killing the turbo if it does run dry not to mention everything else. I have a video on you tube that a search on TD6 Turbo and FFRR should reveal that shows 3 10 minute clips of the reassembly and issues I came across when refitting the turbo.
Here is a link to the youtube footage. If anyone finds another way that doesn't involve a dremmel I'd be pleased to hear of it Thumbs Up
http://www.youtube.com/user/elpeede 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #47011 22nd Jan 2011 6:12pm
darrenmax
watched your vid, i thought it was going to be like that, i'm gonna wait til it stops raining then check it out, thanks, i think i have found the problem, the vacuum pump seems to be the culprit, ill whip it off tomorrow and fit a new seal see if that helps 2002 td6 vogue, 06 supercharged facelift
Post #47015 22nd Jan 2011 6:34pm
