![]() | Home > General > A Fortnight in the airport carpark... |
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287
I have only used valet parking so guess they jump it as clock is never right but then they may disconnect battery not much help afraid - I carry a lithium jump starter when I go to france just in case might be worth looking at |
https://www.amazon.co.uk/DBPOWER-18000mAh-...start+pack
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135
Can it ? Yes - examples here
| Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259
Battery newish (6 Months). Normally starts first time - so maybe I'll be OK. Think I will buy one of those battery jump-starter thingies just in case. It's a handy thing to have anyway.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
yours is a petrol so it should be ok..its the diesels that generally have problems.. ... - .- -.
| Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1279
Left my 5 year old diesel for 4 weeks... no problems. Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
| Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570
I can't see it being a problem, providing you have no power drain.
| Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354
Not had any problem both times I've left my petrol one.
| NVB Member Since: 14 May 2017 Location: Essex Posts: 103
My TD6 with a new battery would go four days at most when it had a 240mA parasitic drain. Now I have the drain down to 100mA and it's been fine up to 7 days (haven't tried it any longer) but I suspect 14 days would be pushing it. If you have the standard 50mA drain that these cars are supposed to have when asleep, and you have a decent battery, I think you will be fine. RR History
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
I've left my Td6 for 12 days recently albeit at home and it started straight away. If you are worried you can always fit a temporary battery in the boot for the duration and fit a battery isolator switch or indeed simply undo a battery terminal to the front battery. This arrangement will ensure that your car operates whilst parked from the temporary battery and will start from the fully charged front battery as normal when you need it. The other thing to ensure is that your key manually opens the drivers door correctly. If it doesn't and you return to a flat battery you have a further problem. |
| appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424
Mine's normally on the drive for over 3 weeks at a time and starts OK, even in the depths of winter. Battery is an 020 and is 3 years old.
| mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 913
If you're leaving the car where there is daylight or fluorescent light, you could plug a solar charger into the boot accessory socket and it'll keep the battery topped up. |
@mpirie. With my luck such a device will probably burst into flames, set fire to the car and then the whole multi-storey car park along with all then cars therein. Wait a minute.... |
| wack61 Member Since: 17 Nov 2017 Location: Cheshire Posts: 104
Probably worth investing in one of the small lithium jump packs though I'd imagine the AA have a guy on standby as it must happen a lot
