![]() | Home > Technical (L322) > water ingress....again |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8751 ![]() ![]() ![]() |
Would start by trying to unblock the sunroof drains info on here on how to approach the job.
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
If you’ve ruled out the sunroof drains, an incorrectly fitted windscreen is the obvious culprit
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
I can't find the drains:(
FrankN Member Since: 11 Feb 2017 Location: Vellmar, near Kassel, middle Germany Posts: 101 ![]() ![]() ![]() |
Hallo Andy ,
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2280 ![]() ![]() ![]() |
Maybe this will help
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
The other thing it could be is the mastic has gone brittle in the roof rack channel at above the windscreen, mine had a slight leak, took a while to find it but after silicon the gap the foot well is dry as a bone and after the amount of rain we have had its a tried and tested result. If it dont work.......burn it!
andywizkid Member Since: 23 Jan 2018 Location: cambridge Posts: 3 ![]() ![]() ![]() |
Thanks for the above...it was exactly that. i removed both roof rack sliders each side and found tons of old mastic and an area where the water was leaking in to the cabin. i re-masticed that area and hey presto (fingers crossed) it hasn't leaked.
so, just to Update...."hey presto" it didnt work.
