Home > Maintenance & Mods (L322) > Changing the CV boot?
Tight777
Had a quick look underneath for the first time and I have the front nearside cv boot throwing out grease.
Any ideas of what a good independent would charge or is it an easy job to change diy?
Post #466310 28th Jan 2018 10:35am
Tight777
Local independent quoting £100 plus vat, Sounds very fair.
Post #466598 30th Jan 2018 2:45pm
It is a bit of a job, you are more or less removing the hub to get it out which means tackling the lower arm joint which can give a fight, and having the right socket to undo the the drive shaft nut! and a hub puller to release the spline.
Price from Indy does seem reasonable
Worth considering other replacement parts on the hub whilst they are at it ? .
Post #466602 30th Jan 2018 3:04pm
Tight777
What else would you look at while it's being done?
Post #466620 30th Jan 2018 5:33pm
Really it is all the joints and bushes on the hub or on the links to the front subframe. If the lower arm joint is tight (read forum member stories!), it may get knackered anyway to allow removal! .
Post #466621 30th Jan 2018 5:38pm
