![]() | Home > Technical (L322) > New EGR |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
anything in the WM that explains this? ... - .- -.
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Best option is to blank the EGR off and write it out of ecu they are a pain anyway! Plus better performance all round Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
you don't have to touch the ecu, just blank and go.......and get better performance and mpg... ... - .- -.
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
...and then fail your MoT, from around April onwards. Are we really still recommending something that depends on the MoT tester overlooking a major fail? Especially when the OP is trying to keep their car fully road legal? |
i thought the new rules referred to dpf's and not egr's....
Depends if you get a jobsworth MOT tester and really can they be bothered checking the EGR to see if it’s blanked off as in theory they cannot mess about in the engine area! Unless they are a member of Greenpeace and want to join the fight to cut global warming then that’s a diffent story😂😂 GET RID OF GR waste of time and money them even beng there more trouble than good...... Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Yes, by recirculating exhaust gas it decreases NOx emissions and it's removal is now failure under the new test rules and both the EGR and the DPF are checked under the new rules.
i've googled and can't find no reference to the egr's ..the only ref is to dpf's.....any links red merle? ... - .- -.
Just finding a link now...
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
If it's a td6 then the EGR is hidden behind a panel. The MOT tester isn't going to remove the panel to check i wouldn't have thought.
@red merle, still can't see anything in the official link, maybe i'm missing it |
@Paul, as long as your emissions are within tolerances ,and i think the engine running better will help then you shouldn't have a problem as far as i can see...
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 ![]() ![]() ![]() |
Many people might take this view: "the EGR on my FFRR will fail and cost me lots of money at some point. Given that the MOT tester won't and can't examine the EGR itself, I might as well get the EGR valve(s) blanked off. As a result my car will run better and it'll save me money."
Good question, well asked! In my view:
