![]() | Home > Technical (L322) > Lowering a 2005 l322 with IID tool |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 834 ![]() ![]() ![]() |
Have a look on the GAP diagnostics website and look for or download the manual. It goes into detail on the height changing method and consequences. I think it even gives examples of changes and how to complete them.. ______________________________
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
on the 2002-2005 FF's you can adjust each mode separately which is handy if you just want to get the access height a bit lower than it is..
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Cheers guys, I'll have a play with it later on.
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Unnecessary quote removed
When it says - 20mm on the IID for motorway setting, is that -20mm from the original running height then rather than -20mm of what you have adjusted it too? |
Just dropped the running height by 15mm, the access height drops by a further 40mm. It's ok though not too low. I'm tempted to go a bit more |
TDSIX Member Since: 19 Feb 2017 Location: Stirlingshire Posts: 210 ![]() ![]() ![]() |
Is there a way to do this on my 2010 4.4tdv8? I'd like the normal running height to be a little lower..I dont have an iid tool.. 2010 FF 4.4 TDV8 Vogue - Gone
^ on yours a height adjustment will affect all three modes.. ... - .- -.
