Home > Technical (L322) > Westie Sunroof
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Westie Sunroof
Ok, Westie owners - have a question about the sunroof. On my 2004 the sunroof blind has a grip/handle and slides back to a point where the handle is always visible and can be operated one handed. On my 2012 Westie, the blind seems to disappear into the headlining and it takes 2 hands to prise it out. There is also a black louvre type plastic fitting between the blind and the roof at the back of the sunroof which seems slightly loose and is probably the cause of a tiny rattle above my head.
So does anyone else's disappear into the roof or is mine missing a stopper?
thanks in advance
Nick Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #467473 5th Feb 2018 10:52pm
doesnt sound like mine Nick..mine has the handle showing .. ... - .- -.
Post #467475 5th Feb 2018 10:55pm
nicksaab
Thanks Stan - its what I thought, it didn't seem 'Range Rover' in its execution! Current Fleet:-
Post #467477 5th Feb 2018 10:57pm
i'll try and take a pic tomorrow for you.. ... - .- -.
Post #467478 5th Feb 2018 10:59pm
nicksaab
Very kind Stan - looking on Microcat, looks like the black louvre plastic is the top of the blind, so the two have parted company. I'll have a good look in the daylight at the weekend. Current Fleet:-
Post #467485 5th Feb 2018 11:15pm
wood78987
United Kingdom 2012 Range Rover Westminster TDV8 Stornoway Grey
You can take a look at mine when your passing Sat morning if it helps Nick.
I'd also like to compare your engine sound with mine, not sure if mine sounds a bit "whooshy" like a split hose. 2012 Westminster 4.4 TDV8
Post #467512 6th Feb 2018 8:51am
nicksaab
Sounds good Lee - see you Saturday - will text a time Current Fleet:-
Post #467516 6th Feb 2018 9:38am
