![]() | Home > Technical (L322) > Passenger seatbelt warning |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2705 ![]() ![]() ![]() |
Sure there's a way to disable the bonging by a certain number of seatbelt buckle insertions into its hole. Read about it ages ago in here. |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Yep, Ignition on, engine not running, doors closed. Sit in and insert drivers seat belt in and out 10 or so times until you get a bong.
nickt68 Member Since: 05 Nov 2010 Location: Herts Posts: 99 ![]() ![]() |
That’s great thank you.
Yes. drivers seat. Doesn't turn off the sensors but stops the noise. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
Great, thanks Grofus, will give it a go |
GavinBell Member Since: 10 Sep 2017 Location: Phnom Penh Posts: 88 ![]() ![]() ![]() |
Nice one.... a simple solution to an annoying issue sorted while sitting waiting for the wife.....though she is the root of the problem. Series 2a LWB Hardtop - ex British Aerospace that was then used in an armed robbery! not by me!
Thanks again Grofus, mission accomplished 👍 |
