![]() | Home > In Car Electronics (L322) > EBAY DVD Changer - "NO DISC" error message |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
The information on the stickers looks to be the same, have you tried using different discs and also putting discs in different slots in the cartridge?
Ian928 Member Since: 16 Aug 2016 Location: Kristiansund Posts: 79 ![]() ![]() ![]() |
As you can see on the picture, there are DVDs in slot 1, 3 and 6. I have not tried the other slots. 2006 Supercharged |
Are they genuine or copied DVD's? I can't remember, but think I have had similar when the region was different to the player in the past. I might see if I can try and put an incorrect region disc into mine and see what it does to compare.
1 and 3 are genuine and was working on a portable player I have been keeping in the car. Number 6 is a cleaning disc.
Bob Member Since: 07 Feb 2018 Location: Kent Posts: 1 ![]() ![]() ![]() |
Hi just had my L322 for a couple of weeks and had the same fault
That is very interesting! We did in fact try the same but were not as lucky as you. We dismantled the old unit and lubricated it with silicone spray so if we get permission to open the new one from the seller we will try to do that.
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Was issue sorted out. I ask as I came across this
Thank you, very interesting! This is the CD player though... 2006 Supercharged |
Ok, now we have tried a third player! This did play some DVD but not all. We sprayed it with silicone and probably got something on the lens. We tried a dry clening disc but that did nothing. We dismantled and cleaned with q-tios with water and dried it off with dry q-tips. We are now back to where it will recognize some DVDs but most of them will show only "NO DISC".
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Ian, use Isopropil (rubbing) alcohol 96% to clean lens
Ok, an update. We cleaned the lens with CRC electronic cleaner and afterwards it plates no DVDs. The day after i again plates the same DVDs it had played before cleaning.
