![]() | Home > Technical (L322) > 007 Smoke Screen! |
| MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 547
No expert on the RR but on the D3 the FBH exhaust exits exactly where you describe. It runs whenever the external temperature is below 6 degrees IIRC. It's purpose is to assist the warming up of the engine and maintaining the engine working temperature. It can also be used for auxiliary cabin heating but it's primary purpose is for the engine.
| Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445
Thanks for the help!
| Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577
The clicking is the fuel pump for the FBH. At least you know that works. |
Ah ok. I wondered if it was the clicking trying to ignite.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Sounds like FBH to me.
Oh cheers fella.
Apologies - not replying to your last question as I don't know the answer - but Robbie has written an excellent guide to servicing and repair of the FBH for the D3/D4 as well as a diagnostics guide (link is at the top of that thread). It's not the same as the L322 FBH but it may still be helpful to understand the workings.
Thank you all so much for the help.
| All times are GMT |
