![]() | Home > Maintenance & Mods (L322) > L322 Td6 06 - Facelift 2010 - Indicators Stopped Working |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
Do the wing indicators work ?
PaulCee Member Since: 31 Oct 2014 Location: UK Posts: 18 ![]() |
Yes the wing indicators work, as well as the side lights and headlights. Everything else works, just the front indicators have stopped working.
Ok. I’ll dig out the wiring diagram to get the right pin for the indicator feed to the unit and you couldsee if it’s getting 12v. signal.
Thanks for the help.
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 230 ![]() ![]() ![]() |
The other way I believe to drive the front indicators on a 2010 facelift is to use a standard automotive relay driven from the side repeater if they have taken this route perhaps the relay(s) have failed. |
I am not the best when it comes to electrics. I was thinking though if I could not find a solution that I could maybe drive them from the side repeaters. Not sure how to test the relay either but I think I know someone that will help.
If you feed the wire for the indicator with 12v, it should light up.
I’ll try to grab some pics of the relay wiring of mine tomorrow, I didn’t do the face lift but the previous did I think with advice from Cam-Tech. |
Hi,
