![]() | Home > Maintenance & Mods (L322) > Drive train noise when reversing |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
If he only replaced one UJ then I’d be looking at the other prop UJs.
Beemergriff Member Since: 06 May 2016 Location: Northamptonshire Posts: 62 ![]() ![]() |
Hi Simon
There is still the front prop. Mine was badly mangled.. |
It only makes a noise when turning. In a straight line it's OK. So . . . may be CV joint on the other drive shaft. Andrew
You are probably right, the L322 was always better at prop management than the older models. ______________________________
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 336 ![]() ![]() ![]() |
If only when turning, then suggests a front cv joint 4.2 SC - sold , now bought back
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
only makes a noise when turning ? as above ... (but CV joints generally make clicking/clacking sounds when gubbed.)
Tyres are all the same, Pirelli Scorpion Zero as a set of 4 last March and on the original RR 18" wheels, so wind-up due to that is not a cause. No adverse sounds when going forward, so more investigation needed.
Ties the same size in your case wont be the cause ... it was more a general comment of not being able to fit different sizes tyres between front and rear.
