![]() | Home > In Car Electronics (L322) > ipod/music streaming |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
http://www.fullfatrr.com/forum/topic45097.html?highlight=tune2air Cheers, Greg
| TDSIX Member Since: 18 Feb 2017 Location: Stirlingshire Posts: 210
Cool, thanks. That's worth a look. 2010 FF 4.4 TDV8 Vogue - Gone
| m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 338
Not cheaper than the cable for a tenner , but I use one of these through the aux port - no track changing from the wheel or touchscreen. I connect to the stock BT for calls and music only to the receiver
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
Have an el cheapo copy cable In the desk drawer will have a look. You are welcome to it for a tenner and postage. I will check it works first as I’ve not used it. Bought it when I got the car but there was one already plugged in. It’s the 30 pin cable so you will need a apple 30pin to lightening connector or an older iPod. There is nothing that can't be fixed with a hammer😜😜
I bought a cable, however it doesn't seem to work.. perhaps i'm being thick?
what iPod are you using?
TDSIX I'm guessing you're using a lightening adapter on the end of the 30-pin cable. It will charge but the cable and system won't allow music from an iPhone 6. I guess blame Apple. Try an older iPod and it should work. To connect iPhone search 'music streaming' here, there are options. I use my old iPod via the cable but I also have an AirPlay box feeding into the 3.5 jack. This allows music from any iPhone but not track control from the steering wheel. Fine if you have a playlist on Spotify. There is also a Bluetooth option that many here use which does allow track control.
Good info base here: http://www.fullfatrr.com/forum/topic45097.html Cheers, Greg
I see. Waste of money then.. It's an aftermarket cable with female 30pin and lightning ends. I guess I should pick up an old ipod then.. 2010 FF 4.4 TDV8 Vogue - Gone
I don't think it's a waste, you've got several inputs, and hasn't everyone got an old iPod in a drawer somewhere? Get a Nano and fill it with music. Plus either an Airplay box like mine or a bluetooth. If you go for the WMA1000 Tune2Air I think it uses the cable so not a waste.
I'll pick up an old ipod.. I was thinking it may be a waste of money as an old ipod would be 30pin, this new cable is lightning. If I can find a useable ipod with lighting, that'll do the job.. but which? I'll need to check if a Nano has lighting.. 2010 FF 4.4 TDV8 Vogue - Gone
Any idea which iPod with a lightning connector, will be compatible? If my iPhone6plus is too new to work, how do I know which iPod will work? 2010 FF 4.4 TDV8 Vogue - Gone
Not sure any. Wasn't clear from your earlier posts but now it's clear your cable is 30-pin to Lightning.
Thanks Greg, that makes sense (pre 2011 tech). I bought the cable on ebay, i'll see if it van be returned or exchanged.. It was not clear I was using lighting however the clues were there (connected to an iPhone6plus) |
| All times are GMT |
