Home > Technical (L322) > Air Suspension Inactive
The Pixie
My RR is a 2003 Vogue - I do not know if this is a L322 or ??
Recently the battery was changed. On the change the central looking system did not work.
I tried to fix the key, but the result was Air Suspension Inactive - it is locked down so I am unable to drive it.
I have looked online but everything I have tried has failed.
I have the vehicle abroad so getting proper RR help is difficult.
Any advice welcome.
Post #468140 11th Feb 2018 6:32pm
Engine running, turn steering fully to left, turn steering fully to right. Ignition off, ignition on and you should be ok. Thumbs Up
Post #468142 11th Feb 2018 6:43pm
^ do that straight after a battery disconnect and reconnection ... ... - .- -.
Post #468201 11th Feb 2018 10:15pm
The Pixie
Tried the steering technique but suspension still inactive, no lights showing on dial either.
Post #468322 12th Feb 2018 9:54pm
Regrettably if you have no lights showing for the air suspension you have a hard fault logged on the ecu which means you need to connect to a diagnostic unit to clear it.
Post #468328 12th Feb 2018 10:26pm
