Home > In Car Electronics (L322) > L322 MOST system aux idea
Page 2 of 3 <123>
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
where is it located on the car!
Post #434171 7th Apr 2017 3:14pm
Ollie7195
England 2005 Range Rover Vogue Td6 Barolo Black
In the centre of the dash behind the touch screen...will post a how to once I've got the connectors and tested it
Post #434187 7th Apr 2017 5:19pm
Simran0211
Have you got any further with it 🤔
Post #434836 13th Apr 2017 8:10pm
Ollie7195
unfortunately not, molex has not yet got back to me, as far as I can understand on the IHU (integrated head unit) you have 4 connectors
1. fibre optic connector
2. large molex style plug
3. smaller molex style plug
4. FARKA connector for radio aerial
the smaller molex connector is where i understand the aux connection loom to be wired in on the face lift versions (06 onwards) where the aux connection is located on the back of the centre console for rear passengers, I found a photo on a disco3 site where someone tapped into these wires and it has exactly the same IHU
Smaller molex connector:
top row left to right is 1-6 bottom row is left to right 7-12
in position 6 (above the brown wire in this photo^) is the ground for audio
in position 7 is audio right (Normally red on RCA connectors)
in position 8 is audio left (Normally white/black on RCA connectors)
this is where you would need to wire in if you can find the right connectors
Only other thing to do is use the GAP IID diagnostic tool to enable the AUX function in the CCF
If this is correct then you should have aux input available on a MOST system!! Very Happy obviously a jack plug will need to be on the other end of the wires to plug into a phone/ipod etc...
Unfortunately I am not looking to keep my range rover for much longer so may never actually get round to testing this mod but feel free to have a go and report back...hopefully with success!
Post #434849 13th Apr 2017 10:03pm
Simran0211
Will do I have a weeks holiday coming up soon 👍
Post #434862 14th Apr 2017 6:32am
Lee Marsh
England 2006 Range Rover Vogue Td6 Zambezi Silver
Unnecessary quote removed
Did you ever get anywhere with this Ollie? I imagine not Sad
Post #468195 11th Feb 2018 9:46pm
Ollie7195
Afraid not it was costing me a LOT of money so it was sold, even though I never got to try it, it should definitely work!
Post #468212 11th Feb 2018 10:43pm
Lee Marsh
Good work anyway Ollie. Shame it didn't quite get to fruition, but I understand. Everytime I try and look at the audio dilemma something else more urgent gets in the way. Mine is an 06 w/ touchscreen but no aux in. Would like to utilise the optical in with apple tv or airport express, but probably too much grief. Even RCA in would be an improvement. All the best Thumbs Up
Post #468222 11th Feb 2018 11:33pm
rickardodiaz
United Kingdom 2005 Range Rover Vogue Td6 Java Black
I CAN CONFIRM IT WORKS!!!
It worked, all wired in and programmed ccf using JLR SDD and it works! Thanks
Post #551675 25th Apr 2020 8:37pm
rickardodiaz
I’d love to know what the other wires on that block connector correspond to though as I was wondering if One of them was for Video in
Post #551677 25th Apr 2020 8:49pm
Roi354
United Kingdom 2005 Range Rover Vogue Td6 Buckingham Blue
Where did you source the pins from?
Post #551913 28th Apr 2020 9:46am
rickardodiaz
I didn’t source any pins mate, I basically got the cable stripped it down and wedged it into the pins, not entirely ideal, but glue them in with hot glue. I’m never going back there again and it’s held and working fine, so didn’t bother, lol
Post #551914 28th Apr 2020 9:50am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Good work Rickardo Thumbs Up Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #551916 28th Apr 2020 9:54am
rickardodiaz
There is also a video i have made, which is on youtube to help people locate and wire the aux in
Post #552124 30th Apr 2020 10:55am
nickguy
United States 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Am also going to do this on my 06 RR SC Full size. Have the AUX port enabled via the IID tool. Pretty simple edition to the CCF. Will report back on my progress. Thank you to all who figured this out.
Post #590638 8th Apr 2021 1:17am
Page 2 of 3 <123>
