![]() | Home > Maintenance & Mods (L322) > Genuine Exterior design bumper question |
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086
cool, i thought for a minute you had the plastic ones |
| Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204
They are genuine and were brand new three years ago when Craig changed them and are about to be refurbed poor quality though the chrome considering there around £600. The design kits make them stand out from the samey ones you always see about |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2298
I can’t work this out one has a gap from the side the other doesn’t and ininstalled identically - I feel a hidden cable tie coming in... also even the decent one doesn’t look great from the side.. I am I missing a trick here?
They are definitely wrong but not having fitted them to mine i can't help. send them to me and i'll fit them to mine and then you wont have a problem anymore . |
Haha maybe one of the other guys could send a side shot? Thanks Current stable:
Nino already did and you can see they are fitting flush with the bumper |
I remember they are on a bracket and is it pressed up enough it can only be the black bracket not right surely? As you can see zooming in they should be really flush
any chance of a low down close up shot either side? Current stable:
| Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3818
From the side it looks like they are about to drop off, are all the brackets in place ? Is the bumper designed / meant to fit this Model Year - something doesn't look quite right - perhaps have a look under a later vehicle to see if all the mounting brackets are the same ? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
I only have the front three bolts in should I have some at the back? Current stable:
No idea, have you checked Topix or the LR website for fitting instructions - there is a whole section dedicated to accesory fitment - may or cover older vehicles tbohgh but worth a look - didn't yours come with instructions ? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
No got it used... Current stable:
| All times are GMT |
