Home > In Car Electronics (L322) > parrot ck3100
steve1
United Kingdom 2006 Range Rover HSE Td6 Bonatti Grey
parrot ck3100
I have a range rover 2003 l322 it has the original radio factory fitted ( no touch screen) is it possible to fit the above handsfree kit ? any tips would be appreciated
Post #468467 13th Feb 2018 4:37pm
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
Yes, mine came with that installed. It does work OK, mutes the radio / CD. However if the volumne is turned down on the stereo, you don't here the phone ring etc Smile 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #468574 14th Feb 2018 12:46pm
do a search, theres a few threads re this.. ... - .- -.
Post #468575 14th Feb 2018 12:49pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Re: parrot ck3100
Sorry but this is my personal opinion ..the Parrot kits are utter crap. I sepnt near on £250 for one for a 2003 FFR a few years back and it was installed by a professional installer. It worked when it wanted, the small screen was hard to read in the light, the knob fell off the selector switch, the battery in it was for ever in need of being changed...
Post #468617 14th Feb 2018 5:36pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
And the other side of that is I've done nearly 100,000 miles in my 2004 with a Parrot CK3100 and its as good as the factory system in my 2012. And I fitted it myself!
Not sure about the issue above though about not hearing it ring when the stereo is turned down though - never had that experience either. Always rings loud enough for me regardless of volume of stereo or even if its not on (that sounds like the mute lead hasn't been installed on the correct channel.
I found the battery in the remote lasts about 4-6 months but you can buy 10 of the batteries from Amazon for £1.99 so its never been a concern either. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #468635 14th Feb 2018 8:18pm
nar53
France 2002 Range Rover Vogue Td6 Giverny Green
I fit a Grom BT module as a replacement for the CD player & it's brilliant. I use it with android auto on my phone & everything seems to work great handsfree. The only gripe I've got if the phones volume is too high music distorts but its just a case of turning down the volume on the phone & winding it up on the amp & thats it.
Post #468672 14th Feb 2018 10:59pm
Danwilderspin
Look at my post on hear from about 18 months ago - I had you kit it was crap so I bought the Bmw bt module and a mic and a generic switch...the rest is already there as there is prewiring in the boot you just have to re arrange the wires... everything is as oem then and works perfectly, you even get contacts come up on the cluster! Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #468744 15th Feb 2018 4:05pm
