![]() | Home > Technical (L322) > Suspension Fault |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
drill a hole in the compressor filter, that might help.. ... - .- -.
Silversurfer13 Member Since: 17 May 2014 Location: London Posts: 83 ![]() ![]() ![]() |
Ah Pal.... I feel for you
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
As Stan says first thing to do the compressor has a filter which inhibits the air being expelled from the compressor as it vents - the filter is full of silica or something similar and it breaks down and forms a dust which prevents the vented air being released so the vehicle goes into extended mode and you get a christmas tree of faults |
The filter silica dries the air on the way in and the expelled warm dry air dries the silica on the way out so that is what it is there for |
Donimo Member Since: 28 Aug 2017 Location: Manchester Posts: 16 ![]() ![]() ![]() |
Thanks, Gents. This was helpful, and will give me a focus for some investigation tomorrow. Current: 2007 RR 4.2 SC, now deceased, written off by an X5
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
To avoid confusion:
Thanks Joe exactly so my fault |
So don't just drill everywhere!
this is what i was referring to,
That's even more information in that thread, Stan. Off the top of your head, is this a simple job (drilling the filter nut) that does not require the battery to be disconnected? Current: 2007 RR 4.2 SC, now deceased, written off by an X5
To save you dismantle the silica filter once you have the brass silencer off cycle the suspension a couple of times and a heap of white dust will come out it is this that blocks the silencer and drilling stops the build up in the future |
Update:
Aah... you don't have the easy lifting straps fitted |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
