Home > Technical (L322) > Lumpy idle and no throttle response
Andyyav
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
When I started my 2007 3.6 TDV8 earlier it sounded terrible was ‘lumpy’ with no throttle response, the battery light was also flashing after a bit of starting and stopping pulling plugs on MAF and MAP sensors it cleared itself and now appears fine......
I’ve had a search and the only thing I could find was egr valve ‘spindles’ coming loose, I’ve had mine mapped out so guess it can’t be them, any ideas? is something on its way out??
Post #469266 18th Feb 2018 11:37pm
Johnsd1v8
United Kingdom 2004 Range Rover Autobiography Td6 Zambezi Silver
Have you blanked the egr fully off aswell as having it mapped out
Post #469340 19th Feb 2018 4:48pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
You can't blank off the EGRs on a 3.6
Post #469342 19th Feb 2018 4:53pm
i think you can stick egr emulates on ...someone down under did it.. ... - .- -.
Post #469347 19th Feb 2018 5:16pm
Johnsd1v8
Well thats new to mate i was told you can do it just like the td6
Post #469375 19th Feb 2018 7:28pm
Andyyav
Confused.....so the egrs are mapped out and not working but could still be causing the issue?
Would the iidbt show this? Or if it’s MAP/MAF sensors? I’m thinking of investing
Post #469512 20th Feb 2018 10:57pm
Andyyav
Update- I replaced both MAP and MAF sensors and all was well......then today I started it when it was warm and the revs sat at about 500 then after 30 secs or so returned to normal....it was no where near as bad as the first time. I’ve borrowed a very basic code reader and there’s nothing registered.... I’ve read on another thread that it could be related to the battery I’ll get that checked next!!
Post #471423 6th Mar 2018 11:04pm
fisha
Could also be the throttle body itself. Certainly on the Td4 freelander engines, the toothed gearing and sensors within it could wear out causing issues with starting and throttle response. Also, cause of the nature of the diesel, oils and gunk can build up around the butterfly causing it to stick.
No reason why a similar thing couldn't happen with the 3.6 i guess. A first port of call my be to take off the pipe running to the throttle body and see if its dirty and give it a clean. V8 or else ...
Post #471462 7th Mar 2018 1:19pm
Andyyav
Thanks for all the infos and advice!
Its been for a diagnostic check today and looks like the egrs are still mechanically working even tho they’ve been mapped out as they are giving fluctuating readings🤔
Also have some voltage below threashold readings and injector differences
I’ve agreed to give some time and see if it faults again and go from there, tempted to have a look at the egrs to see if I can spot anything!
Also looks like I wasted money on the maps/maf sensor as there weren’t any codes stored for them!! At least I have good spares I guess Embarassed
Post #472826 16th Mar 2018 4:57pm
Highgun
Did you find out what the fault was Andy? I have the same problem with mine.
Post #533352 6th Nov 2019 8:24pm
Weegie
https://www.ebay.co.uk/itm/RANGE-ROVER-Vog...2749.l2649 John
GAP iiD BT-Sold
Post #533385 7th Nov 2019 9:03am
DrRob
Bell Auto Services are your folks to do this. Ian Bodsworth is an agent for them too Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #533389 7th Nov 2019 9:38am
Andyyav
Apologies highgun not been on for a while, I ended up parting company with mine, was advised the torque converter was at fault after the Rev problem got worse and I was getting vibrations under acceleration, moved on to a D4 but still miss it
Post #565869 29th Aug 2020 8:00pm
