Home > Maintenance & Mods (L322) > Rear washer...no washing cos there is no liquid!
gingerbiker
2006 Range Rover HSE Td6 Stornoway Grey
The rear windscreen wash wipe is failing to do anything other than scratch the window today as there is no water squirting out. Any solutions/ common faults. The water bottle is full. It's not frozen.
Carl
Post #46675 19th Jan 2011 10:57pm
dan_uk_1984
The pipes run along the roof - they could be frozen. Do you use propper anti freeze/screenwash?
Or it could be the one way valve has failed because of the above.
Post #46676 19th Jan 2011 10:59pm
mzplcg
Blocked nozzles? It's a common problem. If left unfixed it can lead to the motor filling with screenwash fluid. Fairly poor design really.
Take off the upper trim on the inside of the tailgate and remove the pipe from the motor. Place pipe in a jar and test. If it flows freely it's the nozzles. If not, possibly the pump or fuse.
Post #46680 19th Jan 2011 11:09pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
I sent my car into LR for a same problem naively thinking it would be covered by the LR approved warranty. Sadly it was not and I paid about £20 to have the rear jet and one way valve cleaned.
This did the trick and its working perfectly now.
Cheers
Justin
Gone - Range Rover Supercharged 2006
Post #46681 19th Jan 2011 11:14pm
Andy
Mine is playing up- if I push the stalk forwards, I can hear the motor running intermittently, but no water coming out of the back. Anyone else had this? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #46691 20th Jan 2011 12:49am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Noddy
Mine was the same, tried the pin in the nozzles but it only dribbled out, bought a new arm, the old one was so corroded it did not hold the wiper against the screen, and now working fine.
Ian
Post #46699 20th Jan 2011 8:51am
Jem0911
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
http://www.fullfatrr.com/forum/topic884.html
This? 15MY SDV8 Vogue SE
Post #46705 20th Jan 2011 9:40am
Can anyone point me in the direction of the NRV?
Post #46775 20th Jan 2011 3:41pm
Andy
IanV8 wrote:
Noddy
Ian
Cheers. Mine sounds electrical though. If I hold the stalk forwards, it wipes and I can hear the washer bottle motor running intermittently. Sort of a stop start, then it stops altogether. I'm thinking its the contacts in the stalk itself. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #46802 20th Jan 2011 7:15pm
KARMANN
2002 Range Rover Vogue 4.4 V8 Java Black
thats what its supposed to do, work intermitantly. It has a pause so it only scooshes when the scoosher is pointing at the main part of the window. I can assure you its the little valve just before it exits the nozzel. The pipe freezes then burst a little none return type valve and this stops the scoosher from working. Its not an electrical fault!
Fraser
Post #46803 20th Jan 2011 7:21pm
CyberMrT
2003 Range Rover Vogue 4.4 V8 Stornoway Grey
You can buy the valve from you dealer for only £5...probably costs about 10p to make.
Mine has never worked but changed the valve and put pins in the nozel on the wiper arm cap, all good now. L322 2002 4.4 V8 LPG
Post #46814 20th Jan 2011 8:30pm
Just been out to check mine and the rear wiper arm is solid with corrosion. Where is the cheapest place to get a new one and what's the part number?
Post #46831 20th Jan 2011 10:47pm
You can try ebay but I reckon it would be quicker and easier and not much more just to get one from your local dealer. Discovery 4 HSE
Post #46833 20th Jan 2011 11:20pm
I fitted a new rear arm a couple of weeks ago, cost around £20.00 from LR
Post #46922 21st Jan 2011 6:04pm
gingerbiker
No idea my post would create such a flurry of responses; will have a play tomorrow.
Carl
Post #46937 21st Jan 2011 7:41pm
