Home > Technical (L322) > 4.4 TDV8 Gearbox behaviour
longmanh
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
So I took another vehicle for a test drive yesterday (this one: https://www.autotrader.co.uk/classified/ad...amp;page=6 and when pulling away from junctions on at very low speeds, I noticed the torque converter wouldn't lock up straight away so the revs would rise faster than the expected acceleration if that makes sense.
Now I'm assuming this to a certain extent is normal and a gearbox service will perhaps lessen this effect?
Am I right or should the torque converter lock up straight away even at low revs?
Thanks guys.
Post #469144 18th Feb 2018 11:04am
TomCobbly
I think that is fairly normal for the 8 speed gearbox on the TDV8 4.4. Also when the engine is starting from cold it deliberately holds it in a lower gear for longer to help warm the engine up faster. 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #469159 18th Feb 2018 12:56pm
longmanh
Ok, that makes me feel a little better.
I guess it's also getting used to a slush box again with a torque converter.
Most cars I've seen have rust on the arches and upper tailgate.
I'm guessing it's quite a lot of work to get rid of it? Removing arches and either rubbing down and covering up or cutting it out completely.
Some also seem to have rust bubbling up under the black door surrounds, mainly the front doors. I'm guessing this is common as well.
Post #469348 19th Feb 2018 5:19pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
I concur with TomCobley. It is actually quite noticeable sometimes from cold. :thumbs:
Nice car BTW - identical to mine except it has the black grille and highlighter splitter bar (mine are grey).
You might get that for a tad cheaper. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #469371 19th Feb 2018 7:14pm
longmanh
Thanks mate, appreciate the comments.
I drove another one today which had the same torque converter behaviour so I'm sure it's normal.
Yeah I like the car. It's priced pretty well I think, the only things raising questions are the rust and the strong smell from the exhaust but I think this could be the cat being clogged maybe.
It only smells when you're round by the exhaust and not in the cabin.
Post #469377 19th Feb 2018 7:31pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
I am so glad someone has asked, having had mine for just a month I was about to book it in to the workshop to have the gearbox looked at. Although mine does 250 miles each side of the week it does 2 trips of 5 miles on a weekday evening and I was convinced that the box felt like it was slipping when cold on those trips. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #469381 19th Feb 2018 7:35pm
counter of beans
England 2012 Range Rover Vogue TDV8 Santorini Black
I'd say the slightly strained engine note pulling away from standstill is about the only thing I don't like about my 4.4 TDV8. It just sounds a tiny bit coarse, especially when at all other speeds the drivetrain is sublime.
As for that car, it looks really nice but then again photos are no substitute for seeing it in the flesh.
I'd be wanting to check the car's history from the registration plate, and of course the exact mileage; "100,000" is surely an approximation.
Post #469393 19th Feb 2018 8:36pm
GraemeS
Australia
I find acceleration off the mark rather slow because the torque converter is slipped to keep engine revs high unless using very gentle throttle. For normal use, acceleration would be much more brisk if the TC didn't slip so much. Perhaps acceleration is quickest under sustained wide throttle openings if the TC is allowed to slip. However I don't like the engine noise nor want maximum acceleration so lift off once moving sufficiently which then sends the gearbox into a frenzy whilst it works out which gear is appropriate.
Mine's gbox software wasn't quite at the latest level and is now improved at keeping the TC locked in 3rd when turning slow street corners but no discernible reduction in TC slip off the mark.
Post #469401 19th Feb 2018 9:17pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Funny, I was going to ask a similar question to this.
If my car hasn't been driven for a couple of days then the change up seems lazy for a few miles, but is fine after that.
Even if I manually up shift, it is as though it's slipping, as it allows the revs to rise to about 1800rpm regardless of gear.
I also notice that taking my foot off the throttle allows the revs to drop back to ~700rpm as though the clutch is disengaged on a manual, rather than giving any engaged engine braking.
I did wonder if maybe an oil change will help, which I intend to do anyway, but if it's normal behaviour that's less urgent. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #469420 20th Feb 2018 12:14am
GraemeS
Australia
Mine's TC will disengage on slow speed overrun even when hot. It does it every time after lifting off after going through a gateway at the top of a rise then turning hard right on a down-hill run. It re-engages when speed increases or the throttle is opened even just a little.
Post #469422 20th Feb 2018 1:19am
John w
Mine will usually hold on to a gear when heading down hill.
If I manually downshift it definitely will, much like it will do in sport mode.
There is a roundabout at the top of a rise near me. I either have to accelerate to gain speed or manually change up, else it hangs on to the gear. Too many toys, not enough time
Post #469424 20th Feb 2018 1:50am
longmanh
I guess the reason it has all these characteristics is to prolong the life of the gearbox due to the weight of the car. If it was a similar gearbox to the one say found in my E63 which is an MCT, it would just chew through the gears.
That's my guess anyway.
Glad we're all experiencing the same behaviour. Thumbs Up
Post #469427 20th Feb 2018 8:37am
Baltic Blue
When I had my gearbox oil changed recently, they did a software reset at the same time.
For the next couple of hundred miles it was holding gears much longer and the “slip” disappeared, but within a couple of weeks it was back to exactly as everyone else is describing.
I was warned to expect strange gear changes until it “re-learned” my driving style ??
Post #469429 20th Feb 2018 9:51am
longmanh
I guess you can keep doing gearbox resets so the adaptations are relearnt each time or, carry out a gearbox reset, then drive it sports mode or via the paddles so it starts to adapt to a more sporty driving style. Might work.
Post #469432 20th Feb 2018 10:16am
counter of beans
I'm rather sceptical about this "learning gearbox" mularkey. I mean, my driving style is more to do with traffic, weather, time of day etc. etc. I don't mash the pedal to the floor since this is not how one should drive one's Range Rover. But seriously, I don't see how the gearbox can really be that clever when there's so many variables in play.
Post #469437 20th Feb 2018 11:30am
