![]() | Home > Technical (L322) > Rear wheel brake getting hot - parking brake adjustment |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8106 ![]() ![]() ![]() |
Is it harder to turn than the other side ?
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
I have pagid pads from ecp and they are fine. sounds like the hardbrake needs adjusting. You need to rotate the little cog inside the rotors with the handbrake in service mode. They are hard to see but are about 25 past to 25 too depending on the side. Rotate the cog till the wheel wont move then back it off 3 or 4 turns until the wheel moves with little resistance.
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
If you open the caliper pistons, you will see rust....., buy two new calipers, and all is good. Have in my garage lot of 2007er with bad caliper on one side. L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
themule Member Since: 03 May 2016 Location: Yorkshire Posts: 126 ![]() ![]() ![]() |
Thanks guys. I guess the garage didn't know about the reset procedure so that could be the issue. I did look for the adjuster in that area but will check again.
Yeah its done with the iid tool or you can simply hold the handbrake switch down somits off and turn off the key so its disengaged. The cogs are a pain to find but are roughly where i said and you can see if you can get a light through the hole in the rotor. Also sand the surface of the handbrake shoes to remove any excess rust / debris and rough them up again. Current 2007 TDV8 Vogue Buckingham Blue |
Link to epb reset procedure from i post i did
Thanks very much for this help. I found the adjuster today and loosened it off a bit - wheel turned freely and I thought the problem was solved. I tried to do the EPB bedding in procedure as described but couldn't get the parking light to flash so assumed I hadn't got it into that mode. I tried a few times.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3812 ![]() ![]() |
Might be a daft question, but why not just take it back to the garage - surely it's up to them to correcty adjust it ? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
I forgot to update on this.
