Home > In Car Electronics (L322) > FBH?
TDSIX
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
FBH?
I see FBH mentioned a few times, a google suggests this is a fuel burning heater.
Do I have this in my car (2010 4.4 tdv8)? 2010 FF 4.4 TDV8 Vogue - Gone
2007 FF VSE 3.6 TDV8 - Gone
2011 RRS HSE 3.0 TDV6- Gone
2003 FF TD6 Vogue - Gone
2006 FF TD6 - Gone
2007 FF 3.6 VSE - For sale
2011 FF 4.4 TDV8 - Current
Post #469941 24th Feb 2018 9:09pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Yes, you do. Located behind front left wheel arch liner, under the battery.
Post #469942 24th Feb 2018 9:18pm
Vogue
You should also have a remote control to switch it on and off and also to enable remote venting / cooling of the car in summer by blowing / venting outside air into the car 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #469947 24th Feb 2018 10:10pm
TDSIX
Hmm.. I have no such remote.
I see them on ebay, if I buy one I suspect it will need programmed?
..just so I understand if I get one and it works, I just press this from outside the car and it will heat up while im in the house? 2010 FF 4.4 TDV8 Vogue - Gone
2006 FF TD6 - Gone
Post #469959 25th Feb 2018 1:44am
Vogue
Yes, mine works over about 350 metres with a strong battery. They are easy to programme. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #469965 25th Feb 2018 7:25am
nino_nino
all diesel have FBH but not all have remote capability, mine doesn't. you can retrofit remote receiver and get remote controller. I just enabled timed start with IIDTool . it doesn't get that cold where I live. Very Happy
Post #469975 25th Feb 2018 8:29am
Vogue
Remote FBH on Vogue and above was standard on the L322 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #469977 25th Feb 2018 8:35am
nino_nino
Mine has no receiver, I got car in Milan Italy-so different markets different options. TDSIX search this site for the receiver picture and check if you have one in your car.
Post #469978 25th Feb 2018 9:00am
