![]() | Home > Maintenance & Mods (L322) > Rear washer...no washing cos there is no liquid! |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
thats because half of us have a f**ked rear wiper arm.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
I hadn't even thought I had a problem. Thought my rear blade was shot but turns out the arms goosed. New arm to be ordered and then fix the water problem. |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Can the rear wiper arm be replaced by just removing the rear spoiler ? How does the water pipe connect up ?
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
Yes it can it very easy.
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
The spoiler can be removed in minutes, but place an old towel on the roof to lay the spoiler on as the brake light cable is quite short.
Thanks..... |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
LR will blast air through it to clear the crud out of the pipe then it will work again. I had this on my last FF, i could hear the pump trying to squirt the water but no water. A blast of compressed air and viola, worked like a charm.
I'm surprised they didn't charge you for the use of the Viola....
Haha oops, spell check corrected it without me seeing it |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3848 ![]() ![]() ![]() |
I have just had mine in pieces and got 1 jet working well, but the second jet won’t clear.
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
Mine was a blocked nrv which can be cleaned carefully and replaced then cleaned and adjusted the jets all good now
https://www.fullfatrr.com/forum/topic50730.html
timse Member Since: 06 Dec 2019 Location: Farnborough Posts: 37 ![]() ![]() ![]() |
I had a blocked rear washer and took the one way valve (OWV) out as that was knackered. Put a new one on and no joy. I read all the threads about taking the rear washer apart etc but thought there must be an easier way.
