Home > Maintenance & Mods (L322) > A/C Compressor Noise? - Changed to Other Noise!
I think my air con compressor has gone south!
I run with the air con on all weathers / all temperatures
Started to get a loud noise like some one hitting a galvanised dustbin lid with a tympani mallet, usually on overrun when slowing down and then continuing from there until engine speed picks up again. On observation in the engine bay I can see the freewheel pulley wobbling about and "a tinkling noise" can be heard. Everything else seems to be going around OK. The outer cover is loose, can be pulled forward a bit.
Can find 2nd hand for @ £50, so easier to take to my friendly air con people and do a swap, or is there another fix? .
Post #470121 26th Feb 2018 11:15am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
It sounds like the clutch pack has failed, and these can be replaced.
If you're interested, I've got a spare good working compressor that you can have for £46 including delivery. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #470129 26th Feb 2018 12:31pm
Clive603
England 2004 Range Rover HSE Td6 Orkney Grey
Sounds like clutch & pulley assembly problems. Likely the pulley bearings have gone west so its not properly aligned even when the clutch is engaged.
Unhitch the belt and try wiggling the pulley. If it wobbles almost certainly bearing(s) which should be a straightforward fix if you can source the bearing(s). Need to do something fast tho' as extra stress will be bad for the compressor bearings.
If you can get a known good compressor for £50 swop is best & fastest option. I'd grab yours back tho' and investigate at my leisure. If a simple bearing change fixes it for not too much dosh then wrap up well and store just in case the known good replacement turns out not so good a year ors o down the line.
Googling around suggest you can find a new one for £150 - £200.
Clive
Post #470130 26th Feb 2018 12:32pm
Thank chaps. Too flaming cold and snowy to do any lying around on the drive under the car at the moment. I am guessing I can do the swap myself if I get the system degassed... .
Post #470132 26th Feb 2018 12:52pm
nino_nino
Jo, In the meantime turn the AC off if you gonna wait for some sunshine and warmer temps.
Post #470144 26th Feb 2018 1:49pm
@ Nino good point Wink Thumbs Up .
Post #470158 26th Feb 2018 3:10pm
Clive603
OK its Captain Obvious speaking but surely you have checked that the electromagnetic clutch and pulley assembly are still firmly attached. I've seen the odd report of the centre bolt working loose or even falling out completely.
Clive
Post #470170 26th Feb 2018 6:20pm
As said too cold to roll about in the gravel, but will check tomorrow before driving anywhere... .
Post #470171 26th Feb 2018 6:39pm
Hmmm
Seems the noise is not engine rotation speed or road speed (wheel rotation) related
It is (now) like a very loud version of the FBH when it first starts up, and occurs randomly after/during slowing to a stop and moving off again (usually from speed - 50mph to 0) Lasts for 20-30 seconds until drowned by engine noise whilst picking up speed and then seems to quieten down and stop.
Noise seems to come from the FL area when in the driving seat, so could be anything from the HVAC to the FBH
The air con compressor is still tinkling away, so that will get changed anyway.
Any ideas ? .
Post #470668 2nd Mar 2018 11:35am
