Home > Technical (L322) > FBH and alarm
muppet
United Kingdom 2012 Range Rover Westminster 4.4 V8 Barolo Black
FBH and alarm
anyone had this before, woke up this morning to -3 and decided to use the Fuel Burning heater to warm the car up. I aimed the remote at the car, pressed the "on" button and the alarm went off...switched that off and the heater did its job..
I have arrived at work and now the alarm keeps going off at random times, the heater is off, it s all parked up etc...
Initially I thought that the heater switching on had triggered the alarm which I can live with but now it is off and it keeps being triggered is unusual, as always any assistance greatly appreciated....Jeff
Post #424994 27th Jan 2017 7:09am
could be a faulty bonnet switch causing this....clean,disconnect or replace..
Post #425001 27th Jan 2017 7:45am
Closerthanmost
I used my FBH by remote for the first time today. It was working (I could see snow starting to melt) and then the alarm went off about 10 mins later. Unlocked the car and turned FBH off. Relocked and turned FBH on again and alarm went off within a minute - all a bit strange, but not sure how this might be linked to bonnet switch ?
Post #470357 28th Feb 2018 10:22am
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Vehicle battery could be low? Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #470359 28th Feb 2018 10:34am
Closerthanmost
It's a fairly new battery so I don't think it would be that, although I'm happy to be corrected. I thought the FBH would cut out if the battery voltage got too low.
Perhaps I just need to unlock it before using the FBH ?
Post #470368 28th Feb 2018 11:38am
zarnd
Don't believe you do need to unlock it to use the FBH so shouldn't be that.
Check the battery and the bonnet switch for the alarm, both relatively easy to do and to cross off the list.
cheers Alex
2007 M5 Touring
2004 SL55 AMG
Post #470385 28th Feb 2018 1:53pm
muppet
If you are using the remote control function, try pressing the "on" button for a few seconds longer than required, my alarm sounds when I do this but no idea where the connection is between the 2...but my alarm always plays up when the FBH has been activated irrelvant to wether it worked or not. Having it in Land Rovers numerous times I have now given up and just rely on luck if it works or not....I have tried everything but to no avail.... however when it does work it is a real benefit especially days like today..... I need more help than most...sorry !!
Post #470390 28th Feb 2018 2:46pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
If alarm only goes off when the car is double locked....
You may need a software upgrade
The motion of air in cabin generated by the FBH is triggering the alarm
Post #470443 28th Feb 2018 8:32pm
