![]() | Home > Technical (L322) > A couple of TDV8 questions |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 543 ![]() ![]() ![]() |
I've read a fair bit on here about issues to watch out for on the TDV8 and wanted to check my understanding of the "biggies" to be aware of on a prospective purchase:
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8059 ![]() ![]() ![]() |
Post 4 on this thread implies the oill drain mod can be identified if you know what to look for |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2725 ![]() ![]() |
I can see the bottom of mine's turbo and parts of the twin drain when kneeling on the ground in front of the bumper looking up at the left side of the engine.
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1671 ![]() ![]() ![]() |
You wouldn't buy without a test drive so floor the 4.4 above 2500 RPM and look in the rear mirror - you will soon find out if the mod is done.
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 447 ![]() ![]() ![]() |
My car doesn't have the mod and doesn't smoke either.
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 ![]() ![]() ![]() |
Mine is another (2011 TDV8) that doesn't produce smoke even when revved over 2600 rpm. It hasn't had the drain mod, I'm fairly sure. I seem to recall reading that the following were all likely to keep the turbos in good order:
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
That^
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Mike
Many thanks for all the replies. I've now got a better idea what to look for. Just have to find the right car (and wait for the weather to improve!) |
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 ![]() ![]() ![]() |
one more unmodified 4.4 TD here - never had a smooke problem.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
The 4.4’s don’t all smoke all of the time!
Not heard that theory before, but sounds entirely credible ![]() |
TOF Member Since: 13 Mar 2013 Location: Gloucestershire Posts: 53 ![]() ![]() ![]() |
If you keep starting and stopping the engine and running it without the second turbo cutting in, oil will build up in the second turbo. When you do eventually put your foot down, you can get a bit of smoke, but it will just clear itself out and all will be normal. I just try and get my foot down at last once every time I take the car out. The way I see it, is at least the second turbo gets well lubricated. |
Agreed TOF, they used to call it the "Italian tune up". Trouble is, you floor it and you're soon way over any sensible speed - at least round here on Hampshire's congested roads. But you're right, if all my driving is bimbling around then I'm heading for DPF / EGR / second turbo problems at some point. |
