Home > Technical (L322) > Bong, Bong, Bong......
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Here's a strange one. I got engine management fault, HDC inactive, Parking brake Inactive and Transmission fault ( limited gears).
I thought it was a weak battery but have now ruled that out. Around 5 seconds after starting all these faults appear. However, if I start up and just go the faults don't appear until the first time I have to stop. ( for more than a few seconds) I'm thinking maybe an ABS sensor fault.!!! The yellow symbol for that lights up too.
Any ideas appreciated. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #470271 27th Feb 2018 5:05pm
Think you have answered your own question. Check the ABS sensors and the reluctor rings for physical condition and positioning. .
Post #470275 27th Feb 2018 5:32pm
holidaychicken
Can you plug it into any diagnostics ?
Post #470277 27th Feb 2018 7:06pm
Grofus
Thanks Joe.
Holiday chicken, I can plug it in but the car battery is below 12.5v so the diagnostics wont let me play. Its charging up at the moment. I've also noticed the front right skid slightly a few times lately when braking which led me to thinking an ABS fault. Just wanted to throw it out "there" for the input of the wealth of knowledge we enjoy.
thanks chaps Thumbs Up 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #470280 27th Feb 2018 7:25pm
olliecat2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
A low battery in my own experience can throw up all sorts of false alarms. have you tried turning steering wheel lock to lock to clear the yellow triangle warning
Post #470585 1st Mar 2018 6:39pm
Grofus
Yeah, tried the steering lock to lock, battery reset, charging the battery. Pretty sure its an ABS fault on the front right now. Sensor or Reluctor ring. Just haven't had a chance to look yet.
Brought the other FFRR out to play for a few weeks so its all good. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #470590 1st Mar 2018 6:58pm
