![]() | Home > Technical (L322) > L322 2002 Front Subframe |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 404 ![]() ![]() ![]() |
Hi, I've got a front subframe available listed it in the "For Sale" section if you're happy to save a few hundred pounds... Current:
W14shp Member Since: 12 Dec 2017 Location: North Yorkshire Posts: 28 ![]() ![]() |
Can you give me a price and a photo?
It's reasonable. Solid, though has some surface rust - nothing flaking off, just the black powder coating is missing off some/most of it.
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 337 ![]() ![]() ![]() |
Would only cost 50 quid to have that blasted and powder coated , so big saving on new P525
Presume it's the main front subframe and the subframe with the towing eye? |
The engine subframe and front towing eye subframe are 2 separate parts. All of this is now off the car. From memory, the engine subframe is held to the body by 4 bolts and to the engine with 2 engine mounts. The steering rack is also bolted to this subframe. The towing eye subframe is bolted to the the engine subframe and the front chassis legs.
