Home > Technical (L322) > Toothed belt change 2011 4.4 TDV8
666tur
United Kingdom 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Collected the car to play from the dealer. The service guy said the bill to the warranty company was c.£800 and would equate to £1000 retail. To change a belt tensioner! I hope the replacement lasts. 2012 4.4TDV8 VSE
2004 TD6 132k miles- SOLD
1995 Land Rover Defender 110 Tithonus Ex Military
1995 Land Rover Discovery 3.9i V8 manual
Post #470833 3rd Mar 2018 1:39pm
amtrose
2008 Range Rover Vogue TDV8 Santorini Black
Still Squeaking!
Hello All,
I’ve had a similar problem with squeaky belts. Garage replaced tensioner and both belts, but it’s still squeaking😡😡.
They observe that the bottom pulley has a slight wobble and maybe the cause....any thoughts on this?
Post #471455 7th Mar 2018 11:47am
Baltic Blue
I presume they mean the crankshaft pulley?
I can’t think why that should “wobble “.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #471457 7th Mar 2018 12:04pm
amtrose
Yes it’s the crankshaft pulley. Apparently there is a rubber bush in there that perishes and causes the wobble. But it’s only very slight. Does yours wobble... if you’ll pardon the expression sir!
Post #471459 7th Mar 2018 12:10pm
amtrose
An update..... another new belt seems to have cured the squeak. Seems the other one was faulty! Bow down
Post #471888 10th Mar 2018 6:31am
