![]() | Home > General > Thoughts on this L322 TDV8 please |
| longmanh Member Since: 11 Feb 2018 Location: Thames Ditton Posts: 104
Absolutely but I was hoping to find one without rust but I think this is pretty impossible. |
Anyone near chesterfield that fancies having a look at this for me please; https://www.autotrader.co.uk/classified/ad...;dpp=47426
| gg2201 Member Since: 21 Oct 2013 Location: Callington Posts: 158
I am in exactly the same position as you although slightly higher budget. Went to look at two locally to us in Cornwall one with the local Land Rover dealer at Roger young and the other with a prestige 2nd car sales locally where my partner got his C63 which was immaculate.
It's turning out to be a challenge.
| John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 447
Just how rusty are the arches and tailgate ?
| v84x4 Member Since: 04 Mar 2018 Location: manchester Posts: 3
had my v8 vogue for a month and already had oil cooler replaced and now seen that suspension lower ball joint front near needs replacing cars only done 74000 is this a common thing or have i just been unlucky..
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
v84x4 my theory is that higher mile cars 90k say have had the bugs ironed out... 70k seems to be around when the oil cooler goes. £700 sounds like they replaced it. Sometimes the housing cracks but members here have found sometimes just the gasket need doing.
John W it's covered - you have to open the rear doors, peel back or even remove the rubber and you'll know straight away. Plenty here using search. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway Last edited by GGDR on 4th Mar 2018 2:21pm. Edited 2 times in total |
Here's mine which needs doing obvs.:
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Welcome to the world of FF ownership!
I got my first RR on gumtree looked at loads I've just been to see another TDV8 local at Castle Motors again was very tidy. Rear arches were good but the boot showing early signs of corrosion underneath the lip. It had the oil cooler done by LR and had a LR warranty included. Didn't have a couple of options I was after but drove lovely and looked good in Green.
Thanks. I appreciate it's rusty but doesn't look too bad. Mine is nothing like as serious as that, just a couple of chips that I will rust treat and touch in. Too many toys, not enough time 2011 4.4 TDV8 AB Black |
Update;
