![]() | Home > Technical (L322) > L322 vogue 05 will not start HELP!!!! |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
check the connections to the new pump , one might have loosened...funny its only happening since the pump install... |
| GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084
I had a similar problem before Christmas. Eventually they isolated the fuel pump relay replaced it and not had a problem since. FFRR TD6 HSE
| mdzi Member Since: 23 Jan 2011 Location: cambridgeshire Posts: 6
Thanks for the replies. Just to update you I checked the fuel pump today & it appears to be working ok! pulled the fuel filter pipe off and turned ignition on and it was pumping diesel!!! The new high pressure pump was fitted at the beginning of December and has been working fine, I've covered 2k miles since it was fitted. I will check the things you suggested tomorrow to see if this helps and let you know. If anyone else has any ideas let me know and I will be glad to check them as this is baffling me now. I don't want to go to the 'STEALERS' but may have too if all else fails.
Hi GregP
| leeellen Member Since: 14 Jun 2015 Location: wales Posts: 2
Fuel pump relay is in the boot on the right....it the rearmost relay 1st row above fuses. There is a relay underbonnet which caused a friends vehicle not to start....its in the ecu box on the left hand side there's about 8 screws in the lid take it off and you will see a blue relay tucked down in the frontpull it out and put it back in or tap it his was stuck...if that work you need a new relay it's about £6.. |
| birchyman71 Member Since: 18 Feb 2013 Location: stockton on tees Posts: 147
Still possible its the inlne fuel pump under the rear passenger side, mine used to have an intermittent start fault caused by this pump |
Gents, this thread is 4 years out of date |
| steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356
i hope he has got it started then |
| All times are GMT |
