![]() | Home > Technical (L322) > Has my fan just died |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 ![]() ![]() ![]() |
Do you mean heater fan?
http://www.fullfatrr.com/forum/topic781.ht...eplacement
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
Just make sure, then make sure again, you have the replacement FSR properly seated in its locating hole, otherwise you will be replacing it again, in short time |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
As Joe mentions, make sure the fsr is seated properly, it is cooled by the fan and if it's not cooled properly, then it overheats and blows, costing you another 50 quid.
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 816 ![]() ![]() ![]() |
big thanks for all the info guys , -2 here this morning so was dreading the 40 mile drive to Hull but 2 mins up the road the sodding thing sprang into life ! wtf ? no matter what I did it worked spot on , ruddy cars lol , I wonder if the fan was slightly seized and then righted itself ?
Simon,
right ive done as suggested , stripped and liberal dose of lube onto fan axle , just see wether thats the end of it i guess
ive had to order a FSR , fan goes on and off like a tarts underwear |
Hopefully, that'll be the end of it.
Oh and how wrong you were pal ! The 5 pin connector is pretty much mullered , which is obvs why it failed but it had defo been messed with previously , now i need to locate a decent connector ! Wish me luck |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
I'm guessing that's how a lot of them set on fire then?! |
You'll need it. I remember trying to get a replacement OBD connector......no chance, would have had to buy another loom. ![]() Mike |
