Home > Technical (L322) > Key assignment issue...
MattyB1983
United Kingdom 2004 Range Rover Vogue SE Td6 Java Black
Hi chaps, hoping someone can give me some advice regarding a 'key' issue I'm having.
Basically when I purchased my car (2005 TD6) it came with 2 keys. One of which was old and worn that was being used daily, the other was a new one which the owner told me hadn't yet been assigned to the car.
Anyway, I chucked the new one into my draw and carried on with the old worn one for the next 12 months.
Today I decided it was time to assign the new key and start using that as the older one is just about at the end of its life. So I followed all the Instructions perfectly and hey presto, the new key works a treat... strangely though the older one now doesn't... so I went through the process again to reassign the older key and that worked fine, old key now works....but then the newer one didn't.
Basically I can only one key to be assigned to the car, not both...
Where have I gone wrong chaps ??
Thanks, Matt.
Post #471420 6th Mar 2018 10:36pm
pretty sure both have to be paired within minutes ... ... - .- -.
Post #471421 6th Mar 2018 10:38pm
MattyB1983
I did try that, paired both keys one after the other in quick succession.
Whichever key I paired last would work while the first one would not. I tried it both ways, firstly with the new key last and then the old key...
Post #471422 6th Mar 2018 10:40pm
Sandyt
I have the same issue I have 3 keys one locks unlocks starts the car and the remote works another opens and locks and starts the car but no remote function the third just opens and locks the car took it to an indi and they could get any one key to do all three functions then the others perform as above so no matter what only one key with remote function they didn't have a clue why spoke to landrover they didn't either so \i just live wit it
Post #471424 6th Mar 2018 11:05pm
kooky_guy
Aren't the keys numbered? It sounds like both of your keys are the same number...? 2010 4.4 TDV8 Vogue SE
Post #471442 7th Mar 2018 8:40am
