![]() | Home > Technical (L322) > Td6 low pressure rail |
| Steffan1991 Member Since: 07 Mar 2018 Location: Pontypool Posts: 4
I just checked the pressure again knowing it would start because I have left it for a while and the pressure is up to 250kps ish but as soon as I turn it off a d try again now it's back to square 1? Second fuel pump maybe?? |
| Stevie_b Member Since: 22 Jul 2016 Location: East Kilbride Posts: 11
From memory 300kpa before it'll inject fuel, it's usually the secondary pump on the side of the tank which causes problems. How much fuel is in the tank and do you see air being purged through the pipe going to the fuel filter when you turn the ignition on?
Thanks, there is always around 1/4 of a tank of fuel in it and as for air in it I'm not sure but will definitely check in the morning, so 250kpa is a little low?, i ordered a new secondary pump yesterday so fingers crossed thats the problem. |
For anyone who is interested it was the secondary fuel pump, i also removed the egr at the same time, its a1 again now unroll the next time 😂 |
| All times are GMT |
