Home > Technical (L322) > 2011 4.4 TDV8 - Restricted Performance
Baltic Blue
Nino,
This is the best I can find so early in the morning Rolling with laughter
I am guessing that number 5 is the culprit.
Post #471607 8th Mar 2018 9:30am
nino_nino
Bow down Thumbs Up Very Happy
Post #471608 8th Mar 2018 9:40am
Baltic Blue
Nino,
Your own pictures are better than the WM.
Is this the EGR temperature sensor that causes the P040D-00 (2F) Fault code. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #471617 8th Mar 2018 10:46am
nino_nino
You right Mike, however I needed Your PDF to confirm that That is the sensor. now I have to wait for Dan to deliver.
Big Cry
Post #471650 8th Mar 2018 2:36pm
Baltic Blue
Nino,
If changing the sensor permanently clears your P040D-00(2F) error report I will have a go at changing mine, but although the iid has been showing the fault on mine for a couple of months now, I have not noticed any problems whilst driving the car.?
Mike.
PS
Please let me know how much Dan charges for it. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #471651 8th Mar 2018 3:01pm
GGDR
I'll be watching this one too!
Greg. Cheers, Greg
Post #471652 8th Mar 2018 3:25pm
Baltic Blue
I don’t want to upset Nino by calling him a “Guinea Pig”, perhaps “trailblazer “ is more complimentary 😁 Bow down
Post #471655 8th Mar 2018 3:32pm
nino_nino
Mike, I have had P040D-00(2F) fo over two years now-with no ill effects, our friend from down under, GraemeS, replace his only for the fault to cam back in a short time. But since I would like to clean my air intake plenum (it is 20K km past last time i did, I may as well replace the sensor. Very Happy
Post #471657 8th Mar 2018 3:40pm
nino_nino
Mike, have you work for Her majesty's diplomatic Corps at some point in the past? Mr. Green
Post #471659 8th Mar 2018 3:48pm
