![]() | Home > Technical (L322) > Air Suspension Fault Help |
Lew306red Member Since: 26 Feb 2017 Location: Tamworth Posts: 10 ![]() ![]() ![]() |
Hi everyone.
First, have a look at the height sensors, especially the one that is on the bumpstops. Likely this has parted company (they do!). You can effect a repair with a coat hanger or similar to get you going. If not hard fault, might sort itself, a battery reset wouldn't hurt or use the icarSoft to clear all faults.
Just had a look the sensor rod is no longer attached to the plastic arm.
W14shp Member Since: 12 Dec 2017 Location: North Yorkshire Posts: 28 ![]() ![]() |
Just had similar when trying to calibrate my height sensors. Didn't know what I was.doing basically. |
@RR1994
RR1994 Member Since: 10 Mar 2018 Location: london Posts: 8 ![]() ![]() ![]() |
Joe, Thanks (i rebuilt compressor new ring - desce replaced- motor runs when i cross connect at relay) but not with relay In
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
senior moment |
@ RR1994
Joe,
ECU is located passenger side, behind the lower fascia finisher (equivalent to where the OBDII connector is on the drivers side)
joe,
Test / Replace relay ? (usually one comes in the box with a new compressor)
Joe
http://www.fullfatrr.com/forum/topic27157.html
