Home > Technical (L322) > No power ..PLEASE HELP
Mctaggarts
United Kingdom 2010 Range Rover Vogue TDV8 Java Black
Please HELP... Been an RR owner for 6 weeks .. had a thread on here already but here is a breakdown. Most recent garage as suggested I need FULL Landover technical support..
1 wife went to start car, turned over ok on 1st attempt but came up with a rake of fault codes.
2. She turned off engine, locked and unlocked again and tried to start - TFT background remained lit and sat Nav lit up with Range rover and flashing amber light. No dials and did not start
3 Battery changed and green flag supposedly cleared faults
4. Went for a start again and went first time but with faults on dash. Repeated steps 1 and 2.
5. Advised it's an ignition issue so changed out button but no luck
6. Accidentally sat on remote and all windows went down but will not go back up
7. Got vehicle recovered to local RR specialist who worked on it for previous owner - after 24 hrs he has advised full Landover tech support required as
.. he cannot get any power for plugging in diagnostic tool
...has competed the hard reset with no luck on batter terminal
.. windows still fully open
.. car locks and unlocks, lights can be put on remotely and alarm (panic button) is ok
I'm in deep here by the looks of it. If I could even get the windows to close I could have it on my driveway
Post #471798 9th Mar 2018 2:18pm
GGDR
Ignoring your windows (which is weird,) and if you are satisfied your battery is good then starter motor.
What about alternator? Those go too.
I saw your other post. If not starter, and the battery is good and if your Indy can't diagnose it that you've got to get it to a dealer. Cheers, Greg
Post #471800 9th Mar 2018 2:46pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Try holding down the lock button on the key fob , it might shut the windows for you. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #471801 9th Mar 2018 3:30pm
Rich_Allen
Did you ever get to the bottom of this? 2008 TDV8 Vogue SE
2002 TD6 Vogue
2002 Defender 90 TD5
2002 Range Rover P38 Autobiography
2002 Range Rover P38 Westminster
Just a sucker for big bills!!!
Post #500360 2nd Jan 2019 6:51pm
