Home > Maintenance & Mods (L322) > Problems from a weak battery.
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
Is there a list of all the weird faults and symptoms a marginally weak/aging battery will cause?
Post #471727 8th Mar 2018 10:58pm
Anything and everything really Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #471731 8th Mar 2018 11:08pm
Laughing thats so true Alan.. Thumbs Up ... - .- -.
Post #471732 8th Mar 2018 11:09pm
doclees
Well that narrows it. So if the shop battery tester reports it tested good but is showing signs of aging is that enough to warrant a new one?
Post #471751 9th Mar 2018 1:08am
Abso”bloody”lutely sir... Thumbs Up
They don’t need much of an excuse to need a new battery Rolling Eyes Thumbs Up
Post #471753 9th Mar 2018 2:33am
doclees
OK. I now feel better about spending money on something that isn't technically broken.
Post #471754 9th Mar 2018 3:47am
wack61
If I leave mine for a few days I get HDC inactive but it goes when the battery has been charged so I hooked it up to the CTEC and left it overnight , when I started it next morning I got the time showing on the display which I've never had before
Post #471765 9th Mar 2018 9:55am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
What problems or strange symptoms are you experiencing?
I changed the battery on our TDV8 just before Christmas.
The battery was OK according to voltage tests, but was unable the start the car after being left uncharged / not run for 2~3 days.
The Sat Nav & radio would randomly not work & when locked after just opening the door without starting the engine, the main display screen would stay on for long periods.
The battery was only 2.5 years old & a good make, but I decided to change it without doing the better discharge capability test.
I've now fitted 1 of the max size 020 spec batteries & all oddities & starting problems have disappeared & the car will start without any noticeably slowness even after a week of not being used (not needed to test after longer periods yet) Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #471784 9th Mar 2018 11:21am
doclees
A few weeks ago, just after fixing the air leak causing the Lambda fault code, I started with the HDC inactive with start up. Not every time but 1 out of 3 starts. Then a couple weeks ago when driving 500 mile in lots of rain I get air suspension /hdc/ABS inactive. Codes showed the air pressure valve and air pump temp when idle. Tried clearing codes but returned right away. Also iidtool tool said update failed when clearing ECUs. When checking the pump I found the pool of water. The pressure valve and electrical connector were in the water. Pump was dry. Dried it all. Was good for a week or so. Now I also have occasional turn key and no crank. Turn back to position 0 and try again and starts right away.
GAP suggested a full battery disconnect to clear everything AKA a hard reset. If I get a chance to get a new battery today the hard reset will be covered with the swap.
I also get a light triggering stuck thermostat code since I did the thermostat mod and even added the resistor.
In the past when the battery has gone flat or disconnected the automatic all door lock when driving off takes days for it to return.
I do also have the satnav drain so I disconnect it when not driving distance.
Post #471818 9th Mar 2018 5:47pm
doclees
Forgot also the headlight ignition voltage less than 7 volts. I'm no electrical engineer. In fact in physics it was my worst labs but this looks like a problem.
Post #471889 10th Mar 2018 6:58am
I was going to say have you checked the tightness of your battery terminals but if that picture shows your battery earth cable I would suggest you have found the cause of your problems. I would replace that cable before I changed the battery..
You have to wonder how the cable got in that state. Shocked
Post #471898 10th Mar 2018 9:15am
Zoiks!! Shocked .
Post #471943 10th Mar 2018 1:19pm
Yep, that’s broke. There is nothing that can't be fixed with a hammer😜😜
Post #471957 10th Mar 2018 3:27pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Nah.
It's just LR saving money with the new, much cheaper current limiting circuit for battery drain... Laughing
Post #471963 10th Mar 2018 3:48pm
doclees
The break was on the underside as you look down on it. I didn't notice it a couple months ago when I put the negative cut off so the satnav would drain it. Perhaps a change in angle and vibration or me being clueless.
Too late on the battery. Changing over to a new one is when I found the break. No worries. The old battery had at least 4 years on it. Was in car when I got it.
Anyone know if this could cause the battery testing to be inaccurate? Trying to find what the relationship between positive and ground wires should be relative to volts and amps. Don't even know how to phrase the question to Google search.
Post #471964 10th Mar 2018 3:54pm
