Home > Technical (L322) > Can some one give some readings on their 3.0 litre L322 ?
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
Is some one able to give me and example of their live readings of their idling L322 3.0litre BMW to compare.
I'm still chasing a miss in the running.
The high pressure fuel pump on live readings with IID tool BT shows it fluctuates between 4000 to 4900 PSI, it is not smooth.
The live CYL Comp readings would also be appreciated.
Thanks
Post #471884 10th Mar 2018 5:26am
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
have you spill tested the injectors ? I had one leaking off badly , after a refurb the engine was waaaaay smoother
Post #471919 10th Mar 2018 11:20am
Leak off test on the cheap
http://www.fullfatrr.com/forum/topic25333.html?highlight=leak
If it will stop raining, and in between the rugby, i will have a look at readings if my non BT IID does them. .
Post #471945 10th Mar 2018 1:24pm
lounge_on_wheels
Bembo449 , I replaced 2 injectors with brand 2 new ones and had the other 4 cleaned and checked not too many kms ago, so I would assume the injectors were ok, but then who knows.
Post #472066 10th Mar 2018 11:22pm
Reading in kPA
31744 steady as a rock
in pSI
4604
CYL readings between -1 and +1
(Note I did have a fault on the low pressure fuel sensor, but this was cleared before taking other readings, and a new fuel filter about to be fitted!) .
Post #472122 11th Mar 2018 1:46pm
lounge_on_wheels
Thanks Joe90, as mine fluctuates I will see what the leak test reveals once my test kit arrives
I bought this on ebay $36.50 $AUD (approx 20.70 GBP)
[/img]
Post #472212 12th Mar 2018 12:01am
Fancy Thumbs Up .
Post #472227 12th Mar 2018 9:07am
lounge_on_wheels
Joe90, will let me check all cylinders at once so after removing the top cover it should take no more than 1/2 and hour to connect and test all at once. I have another diesel car and friends with diesels so will get shared around.
they work like this.
https://youtu.be/zPNnn0uX-68
Post #472247 12th Mar 2018 11:41am
