Home > Maintenance & Mods (L322) > 4.4 TDV8 Intake
dirtymonkey38
4.4 TDV8 Intake
Attempting to remove the intake from a 4.4 TDV8. Are there any hidden electrical connectors i need to watch out for?
Also can anyone tell me how to remove the connector marked in yellow from the intake? should it just slide out of the bracket or is there a hidden clip?
 2011 RR Autobiography 4.4 TDV8
Post #471999 10th Mar 2018 6:14pm
headless21
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
I have just cleaned my intake out it was full of oily carbon deposits. The clip in your picture is on a fork bracket, just carefully pull it towards the front of the vehicle and it will slide out of the bracket. Just be careful and you should be fine. Current Range Rover Vogue SE 2011 4.4 TDV8
Previous
2003 Range Rover Vogue SE
1997 Range Rover DSE
1990 Range Rover Vogue SE
1985 Range Rover 2 Door
1979 Land Rover Series 3
Post #472004 10th Mar 2018 6:51pm
dirtymonkey38
Thanks Headless. Cant get the thing to budge. I thought maybe it had to be uncoupled and got myself a nice coolant shower. 2011 RR Autobiography 4.4 TDV8
Post #472005 10th Mar 2018 6:53pm
headless21
No mine was stiff, but I definitely just pulled towards front of car. Like I say it's on a fork bracket. 👍 Current Range Rover Vogue SE 2011 4.4 TDV8
Previous
Post #472006 10th Mar 2018 6:55pm
headless21
Just thought another odd thing is the 2 plastic posts that hold engine cover on. I used pliers near bottom of post to unscrew plastic top (as they looked like they would snap using a screwdriver) then a small torx socket to remove small bolt that plastic top is screwed onto. You may have already done this. I was fixing oil cooler leak. Current Range Rover Vogue SE 2011 4.4 TDV8
Previous
Post #472012 10th Mar 2018 7:12pm
dirtymonkey38
Thats what in trying to get too, and the oil pipe that goes into it to replace the o-rings. Didn't realise they need to come out.
Ive made a start when I got back home today after letting it cool down for an hour or so then rain stopped play. Ive got cabin filter scuttle out and engine cover off, loosened hoses off the manifold while they were still nice and warm then got stuck on that pipe.
Thinking of taking a 1 day Topix sub and downloading everything. 2011 RR Autobiography 4.4 TDV8
Post #472020 10th Mar 2018 7:27pm
headless21
If you are only doing the pipe with the 2 o rings then you can access it from the back of the engine without removing anything apart from pollen filter housing 2x 13mm nuts. Then using a mirror you can undo the bolt holding pipe in. Replacing o rings took about 20 mins. I tried that 1st before I realised oil was coming from between oil cooler and top of engine so had to remove air intake to remove oil cooler to replace the gasket. That took 3hrs approx including cleaning air intake which was in a terrible state with carbon build up.
Regards Martin Current Range Rover Vogue SE 2011 4.4 TDV8
Previous
Post #472030 10th Mar 2018 8:24pm
dirtymonkey38
Im doing the gaskets on the oil cooler too. Not sure if they are leaking or if its just residual oil from the turbo pipe. Stinks inside when I come to a standstill. Cars done 85,000 miles so if they haven't failed i'll do it as a preventative measure to save stripping it down again. Will give it a good clean out while its apart. 2011 RR Autobiography 4.4 TDV8
Post #472039 10th Mar 2018 8:52pm
headless21
I see, mine is a 2011 and done 82k so your probably wise to do all at once. If you have any problems or questions just give me a shout I will be glad to help.
Good luck, just take it slowly and carefully and you will be fine. You will be surprised at state of intake you will need plenty of degreaser and a lot of cloths 😆
Good luck with it
Regards Martin 👍 Current Range Rover Vogue SE 2011 4.4 TDV8
Previous
Post #472044 10th Mar 2018 9:04pm
GGDR
Speaking of dirty air intake systems, has any one tried a spray cleaning system - here's one
There are others, this was just the first one that came out.
I've no doubt mine's needing a clean - it's tempting - thoughts anyone?
. Cheers, Greg
Post #472056 10th Mar 2018 9:53pm
rar110
The mechanic has used Revive on my car a few times. The 1st application at about 230,000km made a noticible difference. I now have a maintenance dose done about every 20,000km. ______________________________
Post #472073 11th Mar 2018 12:42am
dirtymonkey38
the stud that one of the plastic engine cover mounts onto has no head on it. Any suggestions on how to remove it? 2011 RR Autobiography 4.4 TDV8
Post #472090 11th Mar 2018 10:26am
Sarchopperman
United Kingdom 2011 Range Rover Vogue TDV8 Epsom Green
I have started a thread on induction carbon cleaning as like you, I noted the build up af tar.
Might be worth addressing the subject separately so we get a really good thread of advice regarding induction cleaning and the pro's and con's based on experience of the various methods.
Post #472096 11th Mar 2018 10:45am
