Home > For Sale & Wanted > [For Sale] 2003 4.4 FF Parts (lots of parts) - UPDATED
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I've updated the list of parts available from my 2003 4.4 Vogue that has been broken for spares, plus other parts available (such as a 2006 tdv6 speedo unit). ANY OFFER ACCEPTED!!!!...almost - Feel free to make an offer for anything as it all has to go.
I'm based in Knutsford, Cheshire (just off junction 19 of the M6) or can post most things.
a/c pipes - couple available - £15
Accelerator pedal assembly (Condition - Good) - £15
Air bags (full set except steering wheel) (Condition - Good) - £50
Air Mass Flow Sensor (Condition - Good) - £20
Air suspension valve block (rear) (Condition - Good) - £15
Air vent (side) (Condition - Good) - £10 each
Air vent centre with hazard switch (Condition – Generally good) - £15
Airbag ECU (Condition - Good) - £10
Aircon heat exchanger evaporator (Condition - Good) - £20
Alarm ECU (Condition - Good) - £14
Battery (Condition - Good) - £25
Battery cable & terminal (+ block) (Condition - Good) - £10
Bottom tailgate (Epsom green 961) (Condition - Good) - £20
Brake callipers (rear complete with carrier) (Condition - reasonable) - £10 each
Brake DSP/Pre-charge pump (Condition - Good) - £20
Brake master cylinder (Condition - Good) - £20
Brake servo pump (Condition - Good) - £20
Seat leathers [heated front and rear in tan] (Condition - Good) - £15
Drive Shaft (front o/s – long one) (Condition - Good) - £30
ECU (Transmission Controller) (Condition - Good) - £15
ECU cooling motor (Condition - Good) - £15
Engine mobiliser ECU (Condition - Good) - £15
Fuel filler assembly (Condition - Good) - £15
Fuel filler cover (Condition - Good) - £15
Gearbox ECU (2006) (Condition - Good) - £15
Gearbox oil cooler pipes (Condition - Good) - £15
Handbrake handle (leather) (Condition - Good) - £10
Headlight leveling ECU (Condition - Good) - £15
Heater control cable (Condition - Good) - £9
Heater core matrix with pipes (Condition - Good) - £30
Horns (Condition - Good) - £10
HVAC blend motors ECB512 (BMW 6917941.9), ECB514 (BMW 6917942.9), ECB516 (BMW 6917944.9), ECB518, BMW 8385556.9 (Condition - Good) - £10 each
HVAC heater control cable (Condition - Good) - £7
HVAC temperature probe (Condition - Good) - £12
HVAC temperature sensor (Condition - Good) - £9
Indicator plastic locking nut - front (Condition - Good) - £5
Interior roof grab handles (Condition - Good) - £7 each
Lower tailgate lock actuator (Condition - Good) - £10 each
Lower tailgate top trim (Condition - Good) - £10
Orange side indicator - £5
Parking aid ECU (Condition - Good) - £15
Plastic oversill (o/s) - (Condition - Reasonable) - £10
Rear bumper top plastic trim (Condition – Reasonable) - £10
Rear door release cable (Condition - Good) - £10
Rear heater blower fan assy (Condition - Good) - £20
Rear rubber door seals (Condition - Good) - £10 each
Rear wheel liners - £15 each
Roof rail trim n/s (front) (Condition - Good) - £20
Roof rail trim n/s (main) (Condition - Good) - £20
Roof rail trim o/s (main) (Condition - Good) - £20
Satnav DVD Drive – broken – anyone want for spares? - £5
Seat belts (Condition - Good) - £10 each
Serpentine drive belt pulley (Condition - Good) - £20 each
Serpentine drive belt tensioner (Condition - Good) - £20
Shock absorber top mount (rear) (Condition - Good) - £10 each
Sill kick plate set (Condition - Average) - £15
Steering wheel leather gaiter (Condition - Good) - £10
Various seat leather pieces (i.e. tan heated rear seat leather, ivory heated rear little seat leather head-rests) - from £15
Various trim pieces (i.e. visors, b & c panel trim etc. )- from £5
Viscous fan (Condition - Good) - £35
Washer bottle pumps (Condition - Good) - £5 each
Water heater control valve block (Condition - Good) - £20
Window glass - Rear door (o/s) (Condition - Good) - £15
Window glass - rear quarter (n/s) (Condition - Good) - £15 Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #467659 7th Feb 2018 2:20pm
Xray charlie
England 2003 Range Rover Vogue 4.4 V8 Giverny Green
Parts available.?
Hi, is the rear subframe still available?
Thanks,Martin.
Post #468673 15th Feb 2018 12:09am
Zebedee
Hi Martin, yes still available. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #468792 15th Feb 2018 10:39pm
Xray charlie
Thanks PM SENT.
Post #468839 16th Feb 2018 10:07am
Xray charlie
Hi,
Good to meet you this morning and thanks for the very fair deal on the parts I needed.
All the best, Martin.
Post #469234 18th Feb 2018 9:23pm
DarkWheel
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Zambezi Silver
Hi Dave,
the door actuator arrived this morning - thanks for the prompt turn around. Very Happy
Cheers
Pete
Post #469547 21st Feb 2018 11:05am
wack61
Bonnet seal arrived today, thanks David
Post #469608 21st Feb 2018 7:39pm
Zebedee
Glad to have helped. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #471793 9th Mar 2018 1:37pm
Many thanks for the A/C compressor Smile Thumbs Up .
Post #471875 9th Mar 2018 11:00pm
its me
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Hiya,Can I have the front nearside and offside wheel arches please. I bought some on line for another RR and they managed to sort of put them together and roll them in half without damaging them. It made a smaller package that they put in a thick bin liner.I will need them sent to Southampton. Thanks Ray. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion
Post #472100 11th Mar 2018 10:59am
wack61
Have you still got the shell, I'm looking for the rear inner wheel arches out of a solid car as mine are missing the bottom 2 inches on both sides
The bits that are visible when you open the back doors
Post #472111 11th Mar 2018 11:57am
p38arover
Australia
Would you have the right hand sun visor clip and be willing to post to Oz? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #472192 11th Mar 2018 10:09pm
Zebedee
Sorry, body shell has gone..... Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #472596 14th Mar 2018 5:04pm
its me
Thanks Dave. The wheel arches have just arrived. Well pleased. Ray. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion
Post #473183 20th Mar 2018 10:36am
JT
England 2006 Range Rover Vogue 4.4 V8 Tonga Green
Hi. do you have the reversing camera as my 06 one has lost its capacitor(probs vibrated off) cheers John
Post #474265 29th Mar 2018 3:34pm
