![]() | Home > Maintenance & Mods (L322) > Water draining from rear screen when top boot opened |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
Yep, reckon it's a design fault. I do the same as you, open half way, wait for water to run off, then fully open it. I used to end up with water on the parcel shelf aswell (still do if I'm in a rush!!).
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
only done this once when i opened it very fast and got a puddle on the self, but if you open and lift normally letting the struts do the work then the water runs down the channels on each side. |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3805 ![]() ![]() |
same here |
The water gets trapped between the glass and the frame.
DeltaC Member Since: 23 Mar 2010 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
I think it puddles on the panel underneath the spoiler at the top. I doubt you can do much to stop it as it probably goes in from the roof when driving.. |
Mine too. PITA. |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
mine does it also but if its collecting under the top spoiler panel could this be affecting the rear view camera i.e water logged inside or something onto no6 Range Rover
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
Hang on, are you saying the water drips from the inside of the glass as if it has collected at the base of the top tailgate when closed?
another conspiracy theory.. |
Bit confused... The rear wiper motor has a washer line connected to it and passes the washer fluid through the hollow wiper shaft to a hose on the wiper arm. The seal on this failed for you and the water dripping on you was actually washer fluid? Mine is def rain water. No washer fluid smell and it only happens after a rain. And the with amount that comes out on both sides (outside not inside, tho) my washer reservoir would be empty in no time. I have been meaning to check where it comes from. Aside from being a PITA, I'm also worried it could be collecting in the hollow bottom portion of the tailgate. And I've read about corrosion at the bottom corners of the upper tailgate more than once... ![]() ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
The water is all outside of the glass ! It must be collecting somewhere in the high level brake light cover assembly and then coming out when the boot lid is lifted - two streams of water (not washer fluid) from each corner of the boot lid.
its obviously a design fault but its not a big problem... |
