Home > In Car Electronics (L322) > IID Tool newbie - I'm hooked
Page 4 of 4 <1234
Baltic Blue
Nino,
I have just thought of something.
When you have your Ctek connected do you switch ignition on again, but not start engine?
If so does the iid voltage change when you switch ignition off?
Post #472256 12th Mar 2018 1:13pm
Baltic Blue
I have just re-tried, but switching ignition on or off does not affect iid voltage reading .
It is always 12.2v until the engine is started. Connecting or removing the Ctek makes no difference.
Post #472266 12th Mar 2018 2:43pm
Mike . i'm pretty sure these are the reason for your readings,
Sitting in car with engine running iid shows 14.7. Volts....the iidtool is reading the alternator voltage.
Stop engine and it pretty soon drops to 12.2 Volts....no alternator charge so it reads the battery voltage.
Connect Ctek it reads 13.7Volts at socket, but still 12.2Volts on iid....the battery charger 'feeds' its voltage to the battery in a different way [pulse?] to the alternator hence the the 12.2 volt reading.. ... - .- -.
Post #472270 12th Mar 2018 3:07pm
Baltic Blue
Thanks Stan, that makes sense, but Nino says he connects his Ctek when using iid?
I will wait to see if he replies.
I have sent a PM to Patrick at GAP to check .
Post #472271 12th Mar 2018 3:16pm
i always run the engine, it's a diesel so it don't cost much.. Mr. Green ... - .- -.
Post #472273 12th Mar 2018 3:20pm
nino_nino
ditto, I run engine to- plus connect ctek for insurance, when changing car config. settings IIDTool turns off and on ignition several times- hence ctek set to supply. and yes IIDTool reads 12.2V with engine not running. I have not done ECU flushing - update- yet. I understand that some of this can take 40+min. to finish. We need somebody who has done it to chime in.
Post #472276 12th Mar 2018 3:54pm
Baltic Blue
Thanks for your reply Nino.
I misunderstood.
I thought you were saying you use your iid with your Ctek with the engine off.
No problem, I will just leave the engine running whenever I connect my iid.
Post #472278 12th Mar 2018 4:10pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
The car can’t be running when flashing ECU. So battery needs to be good or use inline charger or jump leads and a running car works 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #472328 12th Mar 2018 10:52pm
certainly true for an ecu flash , but for ccf and height adjusts then run the engine.. ... - .- -.
Post #472349 13th Mar 2018 8:35am
Page 4 of 4 <1234
